Question about Brother MFC-640CW All-In-One InkJet Printer
PHONE IN MFC -640CW
MY PHONE IS BROKEN AND I NEED TO REPLACE IT
  • coir Jun 30, 2008
    where can i buy a new phone for my fax mfc-640cw
Take my advice....forget BROTHER PRODUCTS.....the company is still in dark ages...
....and stay away from WINDOW VISTA......this os is mor of a hindrance then help
gkat
Posted on Jul 08, 2008
Mfc 640cw has a message unable to clean
This usually means the cartridge itself has developed a problem.
Try removing the cartridge and wiping the print head of the with a clean non-lint rag and alcohol. Then replace the cartridge, sith the printer off if possible. Turn on printer and attempt to have the printer software clean the head again. If negative you may need to replace the cartridge but use an OEM recommended cartridge replacement. After market brands tend to create more issues.
My name is Ed Pinero I am a 10 year veteran in IT and a field service technician.
Dec 29, 2012 | Brother MFC-640CW All-In-One InkJet...
Lost manual for Brother MFC-640CW
Go to the following link which has user manuals, quick start manuals for your multi-function center.
http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-640CW
I hope that this information was helpful and will get you on the right track to solve your problem.
Brian
Jan 24, 2010 | Brother MFC-640CW All-In-One InkJet...
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
How to use the fax?
hi maenes
have a look here on this model Brother MFC-640CW All-In-One Printer
you can get the pdf file form here to download the instructions
riz.
Dec 15, 2008 | Brother MFC-640CW All-In-One InkJet...
Scanner
Download driver and scanning software by clicking HERE
Ha Ha tricked you
really you need to click THIS LINK it will take you to Brother's download area
please rate solution.
BYE
Nov 18, 2007 | Brother MFC-640CW All-In-One InkJet...
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
