Casio tk 1300 error showing E03 - can't fix it with advice from manual
  • Anonymous Apr 17, 2009
    Please tell me how to fix a E03 problem on a casio Tk-1300!?
  • 1,668 Answers
For those about a manual with error code solutions, C-tech has the one that covers these codes: E01, E02, E03, E04, E06, E07, E08, E09, E10, E11, E12, E13, E14, E17, E18, E19, E25, E26. It has remedies for each of the codes. You can find it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_operation_manual.html
Posted on May 26, 2013
Cassio tk1300 is showing error6
The TK-1300 was a great model but I don't have error codes for it any more. You need the error table in the manual. If you need one, there's only one on the net that I know of:
Hope this helps
Jun 26, 2014 | Casio Parts Cash Register PC Desktop
Casio tk-1300 how do i do a initial reset???
Go to the Casio factory product support site and download the user manual.
Feb 21, 2012 | Casio Parts Cash Register PC Desktop
Cash button only registers 2p when pressed to open till. till is casio tk 1300 dont know how to re program it to just open.
Try this:
Turn key to program 0 CASH SUBTOTAL Turn key back to REG and try it. -------------------------------------------------------------------------
If anyone needs more information, the Casio TK-1300 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
Jun 06, 2011 | Casio Parts Cash Register PC Desktop
Hello I have a casio tk-1300 cash register. But he gives to E03. can anyone help me with it. I like to hear. Jarno
occurs when you change the key-setting before you complete an action e.g. you start programming a text PLU and then change the key to X1. This will bring up the E03-Error until you change the key back to programming-mode and finish the programming operation. After you are finished the error is gone.
You can find the key position where something is not completed because this position of the key does not bring up the error when you change to it.
Jan 27, 2011 | Casio Parts Cash Register PC Desktop
This means initialisation has not completed. The machine is trying to complete a memory clear. It is commonly caused by a faulty memory battery. It will also happen if the machine has been turned off long enough to flatten the battery. Work through the initialisation procedure in the programming manual. If you need the manual, it is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
My casio tk-1300 cash register is giving me an E 04, how do I fix it.
You have turned the key before you finished in the last mode. Turn the key back to where it last was and finish the operation, then turn the key.
If anyone needs a Casio TK-1300 manual, C-tech collective has it here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
Jan 17, 2011 | Casio Parts Cash Register PC Desktop
I have a casio tk-1300 how do i cancel all previous transactions and start in the new with out loosing my pre sets there could be 10 years stuff on it. tony
I think you mean you want to clear the daily report. Turn the key to Z mode Press CASH button. this will clear the totaliser areas that most people use.
If anyone needs a Casio TK-1300 Programming manual, c-tech has one here:
Aug 25, 2010 | Casio Parts Cash Register PC Desktop
TK-1550 cash register e037 digit or amount limitation over
It sounds like you have a lock out high amount limitation.
email me so I can send you a picture that will explain it more. My email is deborahrainwater@bellsouth.net
In the subject put the Eo37 error code so I know it it from you. The picture explains it, I will try to explain it since it will not let me paste a picture on here. On one of the programming keys it has been programmed (came that way, or accidentally done) that locks the register if a certain limitation of amont of money has been totaled. In your case $30.00. The manual should show or tell you how to unprogram or change the high amount limitation.
May 26, 2009 | Casio Parts Cash Register PC Desktop
Error code E03
Hi. It could be bad. Your battery has probably failed long ago, and it needed to use it when the power went off. try this:
Turn key to PROGRAM mode.
Power off at wall.
Hold RECEIPT FEED down while turning power back on at wall.
Wait 10 seconds.
Let go of button. You should see 'FFFFFFFFF' on display.
Press SUBTOTAL
Check the printout. Look under the copyright at the bottom right, and you should see a number e.g 10801 or similar. If it's all zeros, you have lost everything, and it will need to have the batt changed and fully reprogrammed. Otherwise, turn to REG mode, and try it.
Mark
Apr 05, 2008 | Casio Parts Cash Register PC Desktop
649 people viewed this question
jasbo
jasbo
