Question about Hotpoint FFM70 Bottom Freezer Refrigerator
Water in Fridge
There is always a puddle of water in the bottom of the fridge under the vegetable drawers. Sometimes this gets frozen if the fridge is turned down too much. Does it need defrosting and how do I go about this?
  • ernestlaw Aug 30, 2008
    I have the same problem. The drain channel freezes about 2" - 3" above the bottom. I have to defrost it with boiling water and keep syphoning it out when it cools using some earth cable sleeve.
    I have had wire down it, and up it, and there does not seem to be a blockage.
    I have to do this about every 4 weeks.
  • Anonymous Mar 25, 2014
    Water flooded my kitchen floor when tried to replace the waterfilter.I had to shut of main of
    to stop the water. Didnt stop with filter out, it did slowed it down when I put in the new filter, but water still puddling under the fridge
    Sergeant:
  • 225 Answers
Hi gchives.
My own fridge had this problem and it turned out to be a blocked drain at the back of the fridge compartment, just below the cold plate. The water is supposed to condense on the plate and run down to a drip channel, and then through a tube onto the top of the compressor, where it evaporates.
On mine, the tube was blocked with gunge so the water spilled over onto the bottom of the compartment. I got a length of earth wire - the sort used for wiring UK domestic ring mains - and poked it down the tube to clear the gunge away. I then chased it through with some hot water and washing soda and it has been fine ever since.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge.
If they do not, please give me more details so I can try to help you further.
Cheers, D
Posted on Jun 30, 2008
I am getting water on my shelves which freeze in the back and under my vegetable drawer i get puddles of water.
Sounds like the water drain in the evaporator case is plugged causing the 'defrost' water to overflow instead of going down under the unit where it is evaporated.
You may be able to blow out the plug if you can get to the drain end under the unit. on in the lower part of the fridge.
Jul 23, 2014 | Electrolux Refrigerators
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water comes into the fridge from the freezer.
You have the drain from the coild froze up. The coils defrost and the water cannot run down the drain so it goes into your fridge.
This tip is all about that and how to fix it.
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
Heatman101
Jan 24, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
There is a puddle of water inside the refrigerator, beneath the vegetable bins.
How many items are in your freezer? I had this problem and there was too much in the freezer, not allowing the air to circulate properly in the freezer, thus resulting in freeze up in the top (freezer) and condensation below in refrigerator section. Additionally, I had the refrigerator setting too cold, which accelerated the problem. I had to thaw the drain hole in the freezer section, below the fan, to allow water to leave freezer during defrosting stage. Hope this helps?
Jan 03, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Puddle of water in front of the refrigerator--
Ur colling unit is etheir broken or not at the right setting
Nov 19, 2009 | Samsung RS2556 Side by Side Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Hotpoint FFM70 Bottom Freezer Refrigerator Logo
352 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
