Question about Sony Cyber-shot DSC-W35 Digital Camera
It put access than after it starts beeping and appears turn the power off and on again
  • 455 Answers
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Posted on Feb 23, 2011
SOURCE:
How to erase memory in Brother 8690 MFC - it keeps printing unwanted faxes which are stored in the memory! It is junk mail and 20 pages long and I want to cancel it. When I press "Stop" and pull the power...
Try to press and hold Job Cancel button until a message Job Cancel (All) appears. Press OK to confirm.
If not working, the next is what I found in user manual:
Remove paper from the printer to stop it printing. Turn it on, if not.
Set Remote Access Code, if not already, pressing Menu, 2, 5, 2. Enter three digits - 1, 2, 3 - for example and press OK.
Dial your fax number from a telephone or another fax machine using touch tone. When your machine answers, immediately enter your Remote Access Code (these 3 digits followed by *). If you hear one long beep, machine is saying that you still have faxes in memory. Then you hear two short beeps, that mean the machine waits your command. Use the dial pad to press 9 6 3.
If you hear one long beep, fax messages have been erased from the memory.
Nov 03, 2017 | Brother Office Equipment & Supplies
The PS3 starts with the logo and the "waves" and
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps.
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
When i powered on my PS3 a red screen appears saying a "Serious problem has occurred. Contact you technical support". I am out of warranty. I formatted the hard disk of the PS3 from my laptop,...
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
you can try some of the options from this menu if your ps3 will allow you to bring it up i really hope this helps you out
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
My 9yr old son's ps 3 when starting up doesnt go past the ps screen - no icons or anything showing. tried switching on and off with no effect, 3 months out of warranty! have seen option for PS3 restore by...
The only other thing I could suggest is if you know someone else with a PS3, to put your drive into thier PS3 and try booting up. If it does boot then you would then be able to back your stuff up on a USB stick, put your drive back in your PS3, do a PS3 system restore and then retreive your backed up data. The only problem with this method is that your friends PS3 has to be on the same firmware as yours is, otherwise he will have the same booting problem.
I hope this helps
Aug 06, 2010 | Sony Playstation 3 (PS3) Console
Computer wont start.
I don't have access to your board details. However, beeps frequently represent memory problems. Try
removing the memory on your system and then putting it back.
You can access your memory on the bottom of your computer. It is likely the smallest rectangular hatch. After powering donwn the computer, remove one or two screws.
Remove the memory sticks by spreading the clips on each side of the memory. After removing them, put them back. This will clean the terminals and ensure a good connection. Before putting the back on, try to boot the computer. If you hear no beeps, all is good. Turn off the computer and put the hatch back on.
If you hear beeps, switch the memory modules. Try again. If you still hear beeps, try one module at a time in the primary memory slot. If one of these works, you should be able to buy a new memory module. Go to a sight like Crucial's and have it tell you what you can add. Perhaps this is a good excuse to upgrade.
You should do this at the kitchen table to avoid any static discharge.
May 20, 2010 | Fujitsu Siemens Lifebook N5010 Notebook
Hard drive corrupted
Either Replace it or try accessing the advanced menu and select option 3
To Access the advanced menu make sure your ps3 is on standby..then hold th power button soo that it turns on and then off again..now press and hold again until you hear 3 beeps (excluding the beep when you turn it on again) it should sound like this beep..............beep beep..
then plug your controller into a usb slot and select option 3
Feb 19, 2010 | Sony Playstation 3 (PS3) Console
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
No menu appears when you switch it on only the wave and colour appears also will not turn off have to turn off from main switc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on, my background screen appears but nothing else loads, not even the numerous areas (Settings, network etc.) all that appears is an icon in the upper right hand corner saying "Press the...
you can try doing this cuz i had the same problem till i did this...Access the PS3 recovery menu
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
