Question about iRiver H10 MP3 Player
Freezing recently my iriver started to freeze. non of the buttons would respond. The only way to get it to respond was to take the battery out of the back and start again however this is short lived as it would freeze again. It has also started to tell me that it can't find the files which is incorrect. All in all it is a right old mess. Any solutions?
  • nDEPth Jul 11, 2008
    I record of the radio. I've used it for over 2 years and it recently started to freeze after I stop recording.
  • vkennell2 Jul 16, 2008
    I can't go to the artist. Only the radio will place
    Master:
  • 497 Answers
Try an upgrade
All the best
tc
Thanks for using Fixya
Posted on Jun 30, 2008
I would like to ask the problem of my iriver clix 4gb the problem is my iriver didn't on or my iriver is I hope you can help my problem of my unit thanks................
If it do not power up at all ..check the battery ..cause it may have connection problems ...if it opens but freezing on start ..look for the reset button ..and reset it ..This is a button hidden in a hole and need to be pressed with the stylus or with a sharp object ..and the unit has to be powered and on when you do it (even if it is in freezing position )
In the first case..no power at all ..you will probably need a new battery cause this one it is either corrupted or lost the ability to store the power ...It might power with the ac charger inserted so its worth a try ..
Jan 14, 2011 | iRiver clix 2nd generation MP3 Player
Iriver E100 freezes on statup - has become unusable
I am have the the same problem but when it freezes u lock it then reset it says hold the turns off
Oct 02, 2009 | iRiver E100 Digital Media Player
Computer keeps freezing up and often gives me a message that says microsoft not responding
Did you install software recently? Did you add on any hardware? You might need to unistall whatever you installed and/or remove whatever hardware you added.
How much memory you have? How many start up programs you have running in the background. There could be numerous things going on that would give you freezing and non response.
Jul 01, 2008 | HP Computers & Internet
My iriver e100 keeps freezing. I tried making a playlist and as soon as I select a song to listen to out of the playlist, the screen freezes and no music plays...
Hey guys,
I had a similiar problem. Apparently when you download music from limewire etc. and upload the music to your iriver, you can upload viruses also. Limewire is very dodgy for this. I'd say delete those songs that are freezing from your player and computer, they may be infected and causing the freeze.
May 18, 2008 | Audio Players & Recorders
Won't Turn On
click the reset button....i was having this same problem and i clicked the reset button and it started working again...
Mar 30, 2008 | iRiver clix 2nd generation MP3 Player
IRiver Clix Freezes Up
I had the same problem. Sent it back and got a new one. They said it is a cold solder issue.
Mar 18, 2008 | iRiver Clix Digital Media Player
Delay in responding to buttons
I have similar situation where mine started freezing for no reason.. I suspect faulty battery.. May need replacing and possibly, recall of battery.
Nov 09, 2007 | Samsung SPH-M500 Cellular Phone
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
1. Turn the player off - you may need to take the battery out to do this.
2. Hold the menu button in.
3. Still holding the menu button in, press the power button.
4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
5. Your internal memory will be formatted and you will now be able to start your X20.
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
Freezes at system initializing screen
Please go to my blog to fix your problem. http://terminaltech.blogspot.com/2007/04/iriver-h10-freezing-at-initializing.html
Mar 14, 2007 | iRiver H10 MP3 Player
IRiver freezes, then dies
Hi frequency squeal = diode short-circuited
Must be replaced - cannot be repaired
Mar 02, 2007 | iRiver iFP-895 MP3 Player
iRiver H10 MP3 Player Logo
50 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
