Menu on screen wont come off
Same as other posts, how to reset eprom so it will lose memory and become normal
Update tv with usb drive
Posted on Jan 06, 2009
Reboot my galaxys from black screen
Run a Hardware Factory Reset A hardware factory reset should be used as a last resort to fix a GS4 . The process will delete all stored information on the GS4 and return the device to its factory configuration; you won't be able to back up your data if you're getting the BSOD. Prepare the phone for the hardware factory reset process by performing a battery reset and pulling out the memory card. You can remove the back panel by pulling on the indentation near the power button. You can leave the SIM card in the device. After you've closed the device, plug it into the charger to avoid losing power during the reset process. To initiate the recovery menu, boot the GS4 by holding the "Volume Up," "Home" and "Power" keys. On the "Recovery" menu, use the volume keys to select "Wipe Data/Factory Reset." Then press the "Power" key to initiate the hardware factory reset.
Jan 03, 2015 | Samsung Galaxy Cell Phones
Factory reset
I don't think it's possible to reset a Faderport in the traditional sense since the firmware is not an EPROM (Electrostatic-Programmable-Read-Only-Memory).
I think it's more likely that the driver on your PC or Mac has become corrupted and needs to be uninstalled and reinstalled.
To do this, we'll need to know more about your platform, especially the DAW. Are you using Studio One v2 or v3?
Aug 04, 2014 | PreSonus Firestudio Project + Faderport +...
My Technika TV model X22/14C-GW-TCD-UK loses all of its channels when I turn it off. I have to retune everytime I turn the TV back on, Any Ideas welcome, many thanks
All sets use a eprom in some form or another that stores the memory of what up/down channels are programmed into the memory of the set-I will presume no box is used in line with this set for signal---very rare for this problem to even happen---next try when turn on to direct enter a known channel and see if set goes there--then manually add it in the menu---if set does not lose that memory at worst you can manually add every channel one at a time.
Oct 30, 2012 | Televison & Video
I've replaced all the batteries and it still won't turn on...?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on to resetting the calculator, at the cost of losing the contents of memory.
Mar 10, 2011 | Texas Instruments TI-83 Plus Calculator
Hi! my phone restarts alone when i start. It is not a problem of memory card because i don't have. i have a samsung G600 it restarts after the display of the name of my operator. the screen becomes dark...
try to remove the battery and switch it on. hence you can do a hard reset for your phone and check.
to make a hard reset, in your keypad menu, type *2767*3855# but be aware that it will lose all your settings but will bring your phone back to its factory setting.
take care.
Mar 11, 2010 | Samsung SGH-U600 Cellular Phone
Model 50v500a blue center screen and red on the sides
never mess with eprom. call the service tech. Memory intialization is done in the service mode. data needs to b written down before intialization. You mess up here and you might as well throw the set away.
Mar 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Key Lock?
Try this! Copied right from the Princeton Graphics support pages. (bless their hearts....'course it wasn't "real" easy to find; it was posted for a different monitor for a different problem... but it seems to work for different monitors... Mine's an LCD19D ... and no, it wasn't posted for my monitor either.)
Your EPROM needs to be reset. To accomplish this please
1) Power off the LCD
2) Unplug your VGA cable
3) Press the up arrow at the same time you power on the LCD monitor.
4) You will see a message "RESET EPROM" 5) Power off the unit
6) Plug in your VGA cable
7) Turn the power on.
Dec 23, 2007 | Princeton Digital VL1719 (Black) 17" LCD...
How can i get my tv to stop automatically changing to menu screen?
What you have there could be one of three possibilities. Micro, eprom or tact switches... Tact switches are the small contact switches behind the buttons you depress to turn the volume up and down or change the channel. Sometimes these small switches can become contaminated or breakdown due to corrosion. What we call in the industry a windex syndrom, because the older crts on some models had the swiches exposed just below the lower ridge of the cry where when cleaning the screen windex could drip down onto the switch and cause the corrosion to begin.
Eprom is another likely suspect. This Ic is responsible for storing an array of information including customer settings and other logics convert what the eprom stores into electronic pulses for any number of fuctions. For example press the volume down on your Tv and the eprom has the information to show you the volume bar, the level the volume bar was last set at and the increments at which you are reducing it realtime.
The Micro is another possibility. It acts like a traffic cop engaging various circuits to do or not do something according to a preset list of conditions. Timers, looking at a particular input or yes even bringing up the menu is tasked through the micro controller Ic or micro for short.
The fact that you can eventually get the unit to operate suggests that something in the logic circuit is failing and will in all likelyhood continue to do so until eventually it doesn't work at all...
Nov 14, 2007 | Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
