Question about RIM BlackBerry Pearl 8100
No sound is comming out of the speakerphone
I cannot hear any ring tones
no sound when using the speakerphone
The same thing happened to my phone. All I did was take it apart. (this is a last resort of course because it will void any warranty you have then again i dont know how they would ever be able to tell since you don't break any "seals") Checked the connection of the speakers and they weren't connecting from the mother board to the speaker bent them back and haven't had a problem since. It probably happened when I dropped it I'm sure you have never dropped your phone before. ;) Also one more thing make sure that the two connectors from the mother board don't touch eachother or it will void the connection again. By the way in case you are really scared youtube has videos on how to take it apart step by step super easy.
Posted on Mar 16, 2009
    Sergeant:
  • 234 Answers
Speaker is fault in your mobile! you want to change the mobile speaker! for that purpose only sound not come!
Posted on Jun 30, 2008
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
There is a function key "fwd/dnd" is keep flashing on My Panasonic kx-t7030x phone. How should I cancel for it?thanks!!!
The slow flashing indicates that your phone is currently set for Call Forwarding.
To cancel from this phone, pick up the handset (or use speakerphone), then press this key sequence: [FWD/DND], [0], [#].
The light should turn off, and you should hear a confirmation tone. Once you hear the dial tone again, hang up using the handset or speakerphone button.
Source: page 3-19 (79) of http://www.google.com/url?sa=t&rct=j&q=panasonic%20kx-t7030x&source=web&cd=2&ved=0CFoQFjAB&url=http%3A%2F%2Fpdf.textfiles.com%2Fmanuals%2FTELECOM-F-R%2FPanasonic%2520KX-TA624%2520Users%25203.pdf&ei=ycQCUdf0O5To9gTK_YDQAg&usg=AFQjCNEt0-JdZEhH0WCSSp6Sl7VOmARFbA&bvm=bv.41524429,d.eWU
Nov 04, 2012 | Lands Phones
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
My phones speaker s not workin...but when call comes ring tone is heard.wat s the problem
your cell phone probably has an internal speaker for you to hold the phone up to your ear and talk and an external speaker that is used for the ringtone and for you to use the talk on speakerphone option. You can try to use the speakerphone to speakerphone and see if you can hear your callers.
If you phone's internal speaker is not working, the phone needs to be repaired or replaced.
Dec 24, 2010 | Samsung Modem Configuration Software...
Call forwarding
Your options are...
Option 1: Hit 7 then 2 then #. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit 7 then 3 then #.
Option 2: Hit * then 7 then 2. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit * then 7 then 2.
Jan 29, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Speaker and ring tones on my BlackeBerry Curve 8310 won't work
profile is in any other mode except silent check the ringing in profile if it is off make it on now u cah hear the ringtones
Oct 16, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
CAN'T HEAR RING TONES ON MY RAZR V3I CELL PHONE
Your outter speaker is damaged - you got to love ebay!
Contact your seller and request a replacement or refund because it will cost you upto $50 to fix it
Jan 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
254 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
