Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
LP130 projector - no light from lamp
We were getting no light from the lamp in our lp130 projector, so we thought maybe it was the lamp, we have replaced the bulb and still we get nothing from the projector. It does power on and we get the green power light but nothing else.
Please advise?
  • 1 more comment
  • Anonymous Jul 21, 2008
    I have 2 LP-130's exhibiting the same issue as you describe.
    When I turn the switch on, the fan starts and the green power light up top comes on...but the lamp does not light.
    If anyone has a solution to this issue, please post it up.
    At first, I thought it was the power connection between the lamp and the projector...What confused me was the fact that at times, the lamp would turn on if I turned the projector over 90 degreees...very strange.
    Thanks in advance.
  • Anonymous Nov 21, 2008
    We have the exact same problem with our LP130... Wish someone had the solution here.
    We also have the same problem with our LP130
    Sniper:
  • 72 Answers
To operate, the LP130 needs all of the following conditions:
1. Both Front & Rear Fans Operating
2. Front Cover Switch Engaged
3. Color Wheel Spinning
4. Bulb trigger voltage and ballast working properly
5. Good bulb with less than 2,000 hours on lamp counter
If the maximum lamp time of 2,000 hours is exceeded, the lamp will not light. The lamp must be replaced and the lamp timer reset before the projector will operate.
To reset the lamp hour counter, press and
hold the reset button, then press the menu/select button (while
still holding down the reset button) for 10 seconds.
Posted on Jul 23, 2011
  • Michael Mclennan
    Michael Mclennan Dec 29, 2014
    Any idea if the front fan doesn't go on, but there is the lightest flicker of the bulb on startup what that means? Have tried Reset. Have several of these projectors with this same issue.
  • 82 Answers
There are several other issue that can arise with this unit
you may want to check out fixmyprojector.com
Posted on Jul 26, 2009
How do I connect my gaming console to my projector
hi yeh you need HDMI to VGA convertor you can get them cheap on ebay
Jul 14, 2012 | InFocus LP130 Projector
InFocus LP130 - lamp doesn't turn on, front fan doesn't spin, LED doesn't turn on.
HOLD THE POWER SWITCH ON BOTTON OF THE UNIT
PLUG THE POWER CORD TO THE ELECTRICITY SOURCE
RELEASE THE POWER BOTTON AFTER 10 SECONDS
AND THEN TURN ON THE UNIT...
OR YOU MAY GO TO THE SITE (freepatentsonline.com) search the brand of the device....GOODLUCK.
Dec 06, 2011 | InFocus LP130 Projector
How do you remove the top cover off on a InFocus LP130
Here is how you dismantle the LP130, I did a screen capture for you can see it:
Mar 14, 2011 | InFocus LP 130 Multimedia Projector
New Bulb in my In-Focus Lp130 wont light
the connection that the lamp plugs into backs out of place preventing the connection from being made. you will have to remove the top. with thetop off, install the lamp and look to see if the lamp connection is going into the connector on the lamp housing. if not, you can get a flathead and push the connector into place on the lamp housing and hold it there while pushing the lamp into place. to keep this from happening again I always used to melt the connector to the lamp housing with a soldering iron.
May 26, 2010 | InFocus LP 130 Multimedia Projector
We have an LP130 and when powered on, there is no ...
this used to be my favorite easy repair. Reset the lamp hrs and you may have to upgrade the firmware. If that fails, try this and your old lamp may still be good. i'm not making any promises,but there could be a simple solution. remove the rear cover. then push the release in the slot on the front cover with a screwdriver (this is opposite the lens side.) remove the cable coming from the top cover to the main board. remove the top. Now, look at the lamp where it connects to the connection at the rear of the lamp housing. Now take the lamp out. Put it back in slowly and watch to see if the male part on the lamp actually makes the full connection to the lamp connection on the housing without pushing the connection backwards. If it does push back, then that's the problem. you can hold the connection on the housing in place while you seat the lamp all the way. I used to melt the connection to the housing with a soldering iron so when you put the lamp in it wouldn't back out again. However, if this doesn't fix it it could be the colorwheel not working. If the colorwheel doesn't spin, the lamp won't light either.
May 20, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projector attempts to light the lamp, but to no avail
the ballast is gone and needs replacing. unfortunately, infocus has no parts for that model.
Oct 30, 2009 | InFocus Office Equipment & Supplies
In-Focus LP-130 and it turns on but the lamp wont fire up, it sounds like the cooling fan goes on and then stops, its a brand new bulb also.. some one said its daughter board that controls the cooling lamp...
the ballast is bad. the fan turns on for the colorwheel, but when the lamp doesn't strike, the fan and colorwheel turn off until it tries again. unfortunately, there are no replacement parts for the lp130.
Jul 17, 2009 | InFocus Office Equipment & Supplies
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
894 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
