Question about Radio Communications
Headphones No sound in right ear piece
  • Anonymous May 11, 2009
    Same here
[img]http://www.goatse.asia/hello.jpg[/img]
Posted on Oct 06, 2009
Your assistance confirmed our original diagnosis - the cable connecting the earpieces needs to be replaced.
Posted on Jul 01, 2008
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
Apr 21, 2016 | SOL Republic Master Tracks MFI...
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
Urban Beatz headphones
OPEN UP THE EAR PIECE OF THE HEADPHONES N MAKE SURE THE WIRES STILL HAVE A CONECTION TO THE SPEAKERS IF THATS NOT THE PROBLEM ITS PROBABLY THE WIRES INSIDE THE CORD ARE BROKEN,GOOD LUCK FINDING THAT BREAK!
Jun 16, 2013 | Audio Players & Recorders
How to open ear piece on denon ah-d310 headphones?
hey ! of course it's possible to open the ear piece !!!!!
all you have to do is to pull the foam off (it's not too hard :)
then you'll have to unscrew 3 tiny screws (get a really tiny screwdriver....and voila :)
i just did it on mine couple of minutes ago
May 03, 2012 | Audio Players & Recorders
After soldering, my left ear piece sounds lower than the right piece
More likely the heat from the soldering iron has damaged the earpiece speaker. The cone is plastic film.
Oct 03, 2017 | JVC Air-Cushion Headphones HA-FX66W
My dog chewed on earphone and the sound is all crackly. Is it possible to get one fixed and what would it cost?
HI. If your dog chewed on the actual hardware and wire strands, this will not be repairable. The strands that carry the actual sound data stream have been compromised and separated from the main strand that runs through the ear piece. This type of trauma cannot be repaired, unfortunately. You will need to replace the entire ear piece set. I can understand that you want to repair and not replace, but this will be the only option in your case. You will need to replace the entire ear piece set or deal with that deteriorating sound quality.
Aug 30, 2010 | Bose in-ear headphones - Black with...
How can I fix an intermittent sound problem on the left ear piece of the Tri-port on ear Bose Headphones? If I take the ear cushion off and touch the speaker inside the ear piece on the headset using a...
I have the same problem. The first one that I bought last 1 year. I bought another one and the same problem has appeared today. I think this is because they are assembled in China. Cheap and low quality manufacturer that is sold at very high prices.
Apr 01, 2010 | Bose on-ear TriPort Headphones
Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Mar 17, 2009 | Bose in-ear headphones - Black with...
No sound on right side
I had such a problem, but I fixed it.
Plase see video on YouTube:
or read this brief text explanation:
Under/behind the ear sponge are four screws - 3 black screws, that holds ear cup closed, and one silver cup, that mounts small piece of plate, that holds the cord.
Gently unscrew, open ear cup, and then first I suggest to check if circuit on that small circuit board is not broken! You can also check wires, etc.
DawidWarsaw
Mar 12, 2008 | Pioneer HDJ-1000 Professional Headphones
Radio Communications Logo
173 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
