Question about Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier
HDMI Problem help me
My ONKYO Receiver TXSR 674 has problem When we connect the Video output to HDMI input and taken the HDMI Output and connected to the LCD i am not getting the Video .I am sure the problem with my Receiver . can you just guide me .
  • 151 Answers
With onkyo amps with hdmi up scaleing you have to tell the amp to let the signal through.To do this first press the setup button and you will see input assign,press enter,monitor out appers,press enter you will see hdmi out NO,flick enter button to the right this will change to yes,you should have a picture now.
hope this helps.
CABLE GUY.
Posted on Jun 30, 2008
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
I have my television, cable box, and apple tv running into the tuner with HDMI cables with the tuner hooked up to surround speakers for the sound. I'm having trouble separating the audio and video. I would...
The only way you can do this is by connecting the Cable Set Top box HDMI directly to the TV HDMI input and switching the TXSR508 to Apple TV. And if you want to hear the Cable sound through the TXSR, connect analogue audio out of the TV to one of the analogue inputs of the TXSR ( Aux or Video In ). You may not get the Cable TV's Dolby 5.1 sound but you will get stereo sound which on using the TXSR's dsp setting ( ProLogic II ) can be made into 5.1.
May 04, 2011 | Onkyo TXSR508 Receiver
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
How to connect a turntable to Onkyo txsr 500
Just like most contemporary AV Receivers, there is no built-in Phono preamp in this unit so if your TT doesn't have one internally, you'll need to get an aftermarket Phono Preamp somewhere to PREamplify and frequency-balance the minute Phono Cartridge output to a useable Line Level you can send to any available Line Level input on the Receiver (CD, Aux, whatever) .
Feb 06, 2010 | Onkyo TX-SR500 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Nov 28, 2008 | Onkyo TX-SR606 Receiver
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier Logo
252 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
