Question about Microsoft Xbox 360 Console
Background of any game is all one color such as blue or yellow.
Hi, Recently whenever a game was put into play the background color would be all blue or yellow and sort of have a starfield effect. It has also acted strange with our dvd movies too. Do you know what could be causing this? Thank you
  • gmarshall Jun 30, 2008
    similar problem. the colours were dominantly red or green flashing. this was intermittant for about a week, but now the screen is just totally black with no display at all. no red lights on the console, just the usual green quad controller light. no soud either
    thanks
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    make sure the connector is plugged in correctly and the appropiate colors connector are plugged in also.
    make sure the switch on the connector is properly set for your type of TV.
    let us know what color of plugs you are using.
    if your using HD or composite or regular Video.
To gmarshall, I had the exact same problem. no video, no audio, no red lights. The problem is that over time, the A/V input sometimes melts. I had to send mine in to microsoft. But before you do, they will tell you to buy a new A/V cable. Dont. Just bring a friend's cable over. This is just to make sure that the problem is with the console. If it still doesent work, you will have to send it in. But if you have had the 360 for more than a year, they will charge you $100. Sorry for the bad news.
Posted on Jul 02, 2008
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Is there a way to copy a document that has text on a colored piece of paper and have the background show up white and the text show up black instead of the background being grey and the text being black?
If the background color is light (yellow for example) you can probably play with the contrast and density settings to make it better, but otherwise you can't, unfortunately.
Sep 17, 2010 | Canon imageRUNNER C3220 Color Copier
Weird colors when dvd is played
i think the video out cable is not inserted in the proper jack try out other video out jacks they are yellow in color.
pls vote me if you find this helpful.
Mar 25, 2010 | Philips Televison & Video
Tekan tournament
Alternate Mokujin sounds
To hear different hit sounds for Mokujin, hold DOWN on the D-Pad or joystick before a match in which you are controlling him. Mokujin will now sound like a block of wood when damaged.
Arcade History Dip Switches
While at the Press Start screen for any of the Arcade History games, hold the select button and you will be given a list of dip switches. You can use these for such things as changing number of rounds or unlocking hidden characters, such as Baek in Tekken 2.
Choose Victory Animation
After winning a round and you see the replay showing, pressing each button( [X], [O], etc...) will result in a different victory animation. This also works when the opponent wins.
Play in 'Devil' mode in 'Devil Within' mini-game
This allows the player to play as Jin in permernent Devil mode without having his life bar drained out. The devil bar will be considered as his laser bar. The downside of this code is that it kills of you opponents faster thus unable to reach a higher combo rate.
Note: You must clear Devil Within under Medium difficulty. Then start a new Devil Within or Stage Select.
FOR THE BEST VISIT THIS SITE:
http://tinyurl.com/ydeuw6k
Nov 11, 2009 | Video Game Consoles & Games
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
My playstation 3 wont recognize any games or movies when inserted.
If your PS3 is not reading disc, but can play demos, music, etc. You need to replace your PS3's lens.
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
- All Songs Cheat Code? Rock Band.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You might be playing the rythm a tad off. Try to keep it at the same pace pretty quickly without stumbling.
The rythm should be pretty quick. Like eighth notes or sixteenth notes if you're musica
Jul 20, 2008 | MTV Games Rock Band for PlayStation 2
Game
tune down the settings in game. example: changing screen resoloution from 1200x1000 to 800x600, also decreasing the quality may help. another thing you can try is exiting ALL applications that are running while the game is running that are not needed, such as any downloading clients or anything that may be using up some of your computers processing speed.
Sep 12, 2007 | Video Game Consoles & Games
How do I reset the ink levels?
Well, theres the problem. Most printers can remember up to three cartridges. That includes color & black. The best way to put it is that each cartridge has a"funger print" that the printer can read, and estimated ink levels can be gaged. There is a way to "reset" the cartridges, but i do not have the document on me. Please email steve@nicesites.org and I'll send it today. I'm not saying it will work 100%, as the reset method is geared for the 56/57/58, but who knows right?
Jun 19, 2007 | HP Photosmart C5180 All-In-One InkJet...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
