Question about Brother HL-5240 Laser Printer
Cleaning heads how do you clea the heads on a canon pixma ip5200 please
    Sergeant:
  • 234 Answers
Have a HP670 printer, about 4 years old. I have replaced one black cartridge with a Genuine HP replacement and even though there is still about 1/3 full of ink the print head appears to have blockages and is giving a poor quality print. I am thinking of upgrading to a new Canon S300 but wanted to stay with the HP a little longer until I work out just what printer we should buy.
I just bought a Calidad refill for the colour cartridge (first time replacement) but the colours are intermittent, as printed on the HP test printout. I have tried cleaning the heads, contacts and used the HP desktop control for print head cleaning many times but with no improvement. Is there some way to clean or soften the print head blockages, such as a sponge with water/method to keep the printer going or is it time to give up and chuck it? If I'm going to chuck it I might as well try anything, it may help other readers if it works!
Posted on Jun 30, 2008
Canon Pixma iP5200 just started to make some thin green lines on photoprints. Colours otherwise OK. Inks are non Canon but long used and previously OK. Have tried tests, cleaning and deep cleaning with...
Are these lines evenly spaced?. Do they always appear in the same spaces?
When printing try and hold the paper so it comes out completely flat and see if the lines are there.
Repost with this additional info and i will try and help you
Aug 19, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
Where can I find a replacement printhead for my Canon Pixma ip5200? Local office supply stores have all cartridges but no printheads. Office Boy Richmond, VA
You can try ebay or Canon them selves, the trouble is they cost about £50, as much a new printer.
Alternatively you could try cleaning the head, its probably only blocked with dry ink. But not using the printer software, you'll have to get hold of a printer head cleaning kit, I've seen them on ebay you'll probably also get them from ink suppliers.
Sep 23, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Why is the orange light on my Canon IP5200 printer keep flashing?
make sure all the catridges are proper and there is no paper jam inside in the printer.
Jan 14, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Dec 08, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Canon Pixma ip5200. Inner cover open
The inner cover is the part where the CD print tray goes. When you look at the front of the printer you should see CANON written above the output paper tray - just like in the picture next to you post. If you can't see the word - just fold up the flap.
Nov 10, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
My canon ip5200 flashes 12 times, n bottom feed light is on.
it is problem your printer is wast tank is full it is service error
Jul 14, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Communication from computer to Canon ip5200 printer is fine but paper won't feed through print heads
i think ur printer driver not properly installed so first u uninstall the printer driver and restart the system after restarting the system reinstall the printer driver and then again restart the system . After restarting the system check by giving a print
Jun 02, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Brother HL-5240 Laser Printer Logo
343 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
