Yes it can be i think the button spring is stuck down .
1 try to put the finger on it gently and rotate it clockwise and anti clockwise slowly and gently if it dosent pop out you take a very thin pin or so and try to insert it from down and try to pop it out but be carefull dont apply a force or you can brek the loks once it comes out you press the rubber part down slowly slowly if it comes out it will be in the normal position.and then put back the key by fixing the lock as it was before
and should be ok.
if dose'nt get fix then have to take it for service center.
thanks
