Hp color laserjet 4700 etb reset
Has anyone there worked out which fuse it is that the printer blows on the etb when it is installed? I have replaced these in other machines and reset the counters successfully - has anyone worked it out ? there is a small pcb where the motor is but the pica fuse there (U1) doesn't seem to be blown.
Any help would be appreciated.
  • tbraswell Sep 25, 2008
    i am trying to find the fuse myself, does anyone have a schematic for the board?
  • tbraswell May 11, 2010
    the old etb's can be re-engineered, i'm still working on it, i will let ya'll know as soon as i have the last bug worked out
I have successfully reset the transfer kit life by entering the service mode then resetting the color page count to zero then powering off then on.  Hope this works for you too!
Posted on Feb 19, 2009
The new fuser units don't have the circuitry to reset automatically. You have to order the aftermarket/rebuilt fusers as they have the fuse to reset the counters built into them. The OEM fuser as is in the new machine does not have this circuitry.
Posted on Dec 30, 2008
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
How do I replace my HP Color LaserJet 4700 Image Transfer Kit? I don't have the manual for it.
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Apr 11, 2011 | HP LaserJet 4700 Printer
How do you install a transfer kit to 4700 dtn printer?
Replacing the ETB (transfer Kit)
of the printer.
Jan 13, 2011 | HP LaserJet 4700 Printer
How an hp 4700 transfer kit looks like in real life ie the pict
Hi, you can see a pretty good drawing of the transfer belt and how to replace it in the ETB Install Guide:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=18972&prodSeriesId=473038&lang=en&cc=us
Scroll down to "Setup and install - general" and click on the link for "HP Color LaserJet ETB - Install Guide (multiple language)."
Jul 30, 2010 | HP 4700N Color Q7492AABA Laser Printer
How to reseting hp laserjet printer ETB
59.XY
PRINTER ERROR
For help press
alternates with
59.XY
PRINTER ERROR
To continue
turn off then on
None A printer motor error has occurred.
X Description
0 motor error
1 motor startup error
2 motor rotation error
3 fuser motor startup error
4 fuser motor rotation error
5 print cartridge motor startup error
6 print cartridge motor rotation error
9 ETB motor startup error
A ETB motor rotation error
B developing disengaging motor
startup error
C developing disengaging motor
rotation error
Y Description
0 no color/black
1 cyan
2 magenta
3 yellow
1. Turn the printer off and then
back on.
2. This message might also
appear if the transfer unit is
missing or incorrectly
installed. Ensure that the
transfer unit is correctly
installed.
ETB motor error
1. Clean the ETB unit
intermediate connector, J36.
If the connector is damaged,
replace it.
2. Reconnect the connetors J38
for the ETB motor and J1111
on the DC controller PCB.
3. Replace the ETB motor.
4. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Jun 25, 2010 | HP LaserJet 5550 Printer
I have hp printer 4700 color laserjet .i installed new image transfer kit but counter not reset automaticaly .plz help me how i can reset manually . thanks
What I recommend you to do is turn off the printer, disconnect it from main power for a couple of minutes and then connect back and then turn on and counter suppose to reset by itself.
Feb 27, 2010 | HP Color LaserJet 2600n Printer
HP Color LaserJet 4700 Not Booting
Check if fuser and toner cartridge and image transfer belt are properly installed. Also check if covers are properly closed. One more thing, disconnect printer from main power for a couple of minutes and then turn it back on. Hope this helps. Maybe you can tell me what happened before this started(ex. paper jam).
Oct 24, 2007 | HP LaserJet color laser printer
ETB ASSEMBLY
Probably www.laserpros.com/pdf/HP 2600-2605 fuser-etb.pdf will help...
Oct 22, 2007 | HP Color LaserJet 2600n Printer
ETB Installation procedure
Hi I hope this is helpful for you. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00314345&prodTypeId=18972&prodSeriesId=238800 Good Luck.
Sep 12, 2007 | HP Color Inkjet cp1700ps Printer
3,282 people viewed this question
jasbo
jasbo
