My toshiba laptop l10 281 has stopped working it was working perfectly and was shut down properly wen i went to turn it on again today it wont go it wont even light up please help!! thanks in advance john
    Sergeant:
  • 287 Answers
If nothing at all works then perhaps you have no power to the system.
Check that the powerpack is getting power (does it hum or get warm when plugged into the mains socket?) Check all connections to the power pack and back of laptop.
Try taking the battery out and powering up on only the power pack
Do you know anyone with a similar laptop that you could swap power pack with?
Posted on Jun 30, 2008
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Hello. I have a Toshiba c650-18k laptop . I was playing on it.and wen i went to shut down before shutting down it just went off.and wen i tried to turn it on again it is not turning on.I put my laptop on...
Is there any lights indicators lit up on the laptop?
remove the battery and the ac adaptor and press and hold the power button (for 10-15 sec) with the battery and power cable unplugged
now try powering up the laptop
check whethere the bluetooth and the power light is lit up
this indicates that there is a memory dump issue in this case you need to reseat your memory strips
for that underneeth the laptop there will be memory door
unsrew door the and open the door and you can take the memory strips out and reseat it back
Dec 26, 2010 | Computers & Internet
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Acer laptop wont start up.
You have corrupted files on your system, either from a hard drive beginning to go bad or from just a bad update, use your recovery console, either available during start up or by using the windows cd to boot your computer and have it run a recovery, you will have to re-apply some of your service packs afterwards. Another option in the recovery console is to use your system save points, if you have the recovery console installed then use it to restore your compter to a day before the update.
Sep 30, 2009 | Acer Aspire 5520-5908 Notebook
Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
Jul 18, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
