Computer wont boot up at all.
My sister-inlaw has an older computer (Gateway 2000 manufactured 10-28-97) someone installed windows xp home edition ( I think not licensed) she does not have any CD's to reinstall or bootup.
The computer wont boot at all and I can not get in to fix the problem.
Error is Lost or corrupted file ( \system32\hal.dll) etc.
serial# is 0008249463
The origanel OS was windows 95B. My thought is that since the OS 95B only cost about $15 to $30 these days she should just buy and install the origanel OS. The Computer is not set up with that much RAM and I think it would run as it was designed.Brtter than it did with xp anyway.
Now all I have to do is convince her to buy it , unless you all have a way for me to accesse it to fix the problem.
Paul. Thanks
    Genius:
  • 2,785 Answers
Without windows cd you cant solve the error.
Posted on Jun 30, 2008
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
Aug 18, 2011 | Microsoft Windows XP Home Edition
My windows xp home edition has crashed and i have no recovery cd
Find a friend with either a "retail" Windows XP Home Edition CD-ROM disk,
or with an 'OEM' ("original equipment manufacturer") equivalent.
Use that disk, plus the 25-character product-key on the label on the side of your computer,
to reinstall Windows, or first to try to "repair" your installed copy of Windows.
Or, if you have a "brand-name" computer (Dell, HP, IBM, Lenovo, Acer, Gateway, eMachines)
telephone the manufacturer, and order a replacement "System Restore" set of CD-ROM disks.
Probably about $20, plus $20 for overnight-courier.
Nov 22, 2010 | Computers & Internet
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
Ive been trying to set up a new computer with an older family pc. It has windows xp home edition on it, but everytime i boot it up it doesnt go past the startup screen and says i need a start up file.
Check whether the hardware requirements of XP matches yours. If there is no problem, check for any error in the hard disk. You can use any of the bootable disk management tool. I recommend Hiren Boot CD or Knopix (linux) because both are free and easy to use. Format the disk partition to NTFS. And try installing Windows now. If still there is a problem then your XP cd maybe corrupted.
Sep 19, 2010 | Microsoft Windows XP Home Edition
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
May 18, 2010 | Dell Dimension 8400 PC Desktop
I qant to install windows xp
Get a bootable windows xp cd first.
Boot the computer and enter the bios.
Change the boot priority and make the computer boot through the optical drive.
Then save settings and reboot placing the cd in the drive.
The computer will boot through cd and show the main menu which allows you to format and install the xp select install and you will be able to do so
May 02, 2010 | Microsoft Windows XP Home Edition
Would like to know if there is a way to install GIga Pocket without wiping wIndows Professional XP3 clean just to install Windows Xp Home Media Edition
XP Home Media Edition is technically a customized version of XP Pro. If you want to install the two versions side by side, you'll need to Dual Boot the computer, which requires changing the partition. There are various utilities out there that can do this, but it may end up causing problems for the older version of Windows. Do some research on setting up dual booting and decide if you're comfortable going that route. If not, consider having a technical friend or professional doing it for you.
Oct 24, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
Windows XP installation
Make sure you back up any important files on that gateway machine before you install Windows XP Home because you may lose some during installation. You definitely will lose files if you chose to format the hard drive during your installation of XP which is recommended. After you backup, everything should be a breeze.
Dec 30, 2008 | Microsoft Windows XP Home Edition
Compaq 4400us windows install fails on errors
Microsoft Windows XP help Windows XP is available in the below versions:. Home Edition - Full / Upgrade ... Computer
Additional information and help with the boot.ini. If multiple operating systems are setup in the boot.ini, as the computer is booting you will ... Microsoft Windows XP Home Edition Microsoft Windows 2000 .
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Compaq (388746-001)...
Computers & Internet Logo
88 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
