Question about Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive
The hard drive may have crashed?
It was making loud screeching noises so my husband rebooted. It wouldn't load windows xp. It still shows the toshiba satellite a20/a25 screen but that's we tried pressing F8 for safe mode and it wouldn't boot in any of the choices given. Upon trying to reboot again it now says there is an IDE error, insert system disk. So we tried installing the restore disk provided and it won't complete the install.
Do you think the hard drive is dead or is there still any hope? I have tried to get into the bios, but am not sure which button to press on his system...delete works on most. Any other suggestions?
  • 101 Answers
First your XP should have the system files means bootable files and do the format of the dard drive then do the drive partion and start the xp instalation. you are still you are not clear of this problam cheeak with another pc with working status
Please remove the jumper from hard drive and instal as additinal storage on another mechine and cheak the harddisk the drive is ok then delete the all data and do the fresh partions
Still you are not solove the problam goto the nearest service center they will clear the problam
Posted on Jul 07, 2008
Toshiba c855 screen went black
Try to reinstall windows formatting your Hard Drive... It seems to be an windows crash, or some software.
May 10, 2013 | Compaq Presario Computers & Internet
I have a 99 Ford Superduty 7.3 Diesel. It is making a really bad grinding/screeching sound just after it starts and is warming up. It wouldn't ******* off all the way even after the key was turned
indicates that the starter motor is stuck in the ring gear
possibly faulty starter relay or starter solenoid
pull the starter as the pinion over ride clutch is probably damaged ( noise ) and have the start circuit and relay checked
have the starter bench tested for serviceability by an accredited auto electrician
May 03, 2017 | Cars & Trucks
System tries to load windows xp, then just reboots itself continuously. tried different hard drives with the same result
Because if you change the HDD ussualy the windows doesn't automatically works. Loading the drivers and settings for another mainboard will make it CRASH. Put an empty HDD and reinstall WINDOWS. Ask for directions here
Nov 30, 2012 | HP Compaq nc6400 Notebook
Toshiba satelite p200-ab1 formatted drive which previously had windows vista and now want to load windows xp but will not recognize a drive to load to. if I try nto reload vista it will take but why not...
Before you attempt it, make a couple of changes in the BIOS to hopefully work around a few problems that might crop up.
At reboot, tap the F2 key to enter setup that will allow you to make a change in the BIOS.
Disable caching module before you change the drive sata settings.
Set the hard drive to "ATA compatible."
Aug 08, 2010 | Toshiba Satellite P200-0TD00Y Notebook
My computer had some problems so i rebooted it but when the windows xp logo came in it suddenly stops and starts making weird noises. It also happened before i rebooted when i watch some videos online.
Sounds like your hard drive is crashing or has crashed. You will most likely need to get a new hard drive and reinstall Windows on it. I hope you have your important files backed-up.
Mar 13, 2010 | Acer Aspire One PC Notebook
I cannot get my computer to start at all.
Noises made by your HD is a clear sign of mechanical problem, your laptop cannot access the system files on your HD anymore. Have the HD replaced.
Dec 15, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
1) If you are trying to install from a bootable disk and trying to make a fresh install, you will not come across this error.
2) If you are trying to repair the existing installation, you might need to use FIXBOOT command and try. Please refer the below link before you try this.
Apr 21, 2009 | Computers & Internet
Loading problem
I take it you see the hard drive when you boot to vista cd. doing install can you remove partition and then create new partition format and install vista software. have you tried that if so sounds like your hard drive is working and can delete and reset drive partition index. if your crashing in post then you need to push the tab key when toshiba logo appears should switch showing post BIOS boot on screen all text you should try pressing the setup key as soon as you see the num loc light blink on your keyboard the driver is loaded press f2 then tab key to check post boot.
please let me if this helped you.
Mar 21, 2009 | Toshiba Satellite A300-0CF035 Notebook
SanDisk Cruzer Micro 2 crashes my system!
Hi marykins,
When you say 'crash' does this mean the system reboots, freezes up entirely, or blue screens?
I've seen similar issues when the USB 2.0 host controller isn't enabled in the System (BIOS) setup. Many devices, such as USB mice and MP3 players and even flash drives, will show up and some will function, but if the USB is required to act as a host controller, devices such as external hard drives and (sometimes) flash drives will either not show up at all on the computer or will crash it.
I'd suggest first looking in the BIOS setup to make sure that both the USB host controller and USB legacy support are enabled.
Mar 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive Logo
775 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
