Question about Hotpoint Washing Machines
How to change drum bearings on hotpoint first edition washing machine model wma22
  • Anonymous Mar 18, 2014
    drum has dropped on left side of wasting machine causing flex pipe to come undone.
    Problem Solver:
  • 5 Answers
Right - all washing machines are pretty similar except between manufacturers such as Dyson, who use such things as three seperate drums.
The average washing machine is simply a motor attached by a belt to a drum, with a programming unit that connects to a door sensor and heating element, and a seal that goes around the drum.
Since we are dealing with Hotpoint, the first thing to do is take off all panels from the front, the top, and the back.
From the front: You will be able to see your drum, and should be able to undo the seal. Basically at this point, unscrew everything attached to whatever I describe - remembering where they go. Now the front seal is sometimes attached to the case that surrounds the drum - usually with a heating element attached to it on some models.
From the back: You will see the belt attached to a flywheel that turns the drum. Rotate the drum to check that the rumbling / banging noise is still occurring. Check that the drive belt isn't damaged or worn as this can cause problems. Unscrew the huge bolt that holds the flywheel on to the drum (rotate anti-clockwise). This will usually take a lot of force and is better to use a large spanner, lock it in place, and turn the actual drum with your hands if you can't undo it. Now when this comes off, you will be able to pull the drum free. Move it around until it comes away. The bearings may drop off the drum's shaft so retrieve them. Check to see if they fall apart as this indicates the bearing's seal has gone totally. This is the part to replace. Buy a replacement the exact same size for your model of washing machine and reassemble - ensuring that all screws go back in the right place.
Hope this helps. Remember that it is just a case of unscrewing things in the right order. You learn best by just doing - so if you are mechanically minded - this sort of thing will be a doddle. If you get stuck and can't remember how to reassemble it - call out a repair man and watch how he fixes it as this will of course allow you to try it if it goes bad again ( a common problem I've been told with Hotpoint and Zanussi models since they are manufactured using cheaper parts than others. )
Posted on Nov 09, 2009
Hotpoint wma22 not draining water properly
Take the hose of the back clean and blow through.check filter.Allso check bushes on motor
Aug 16, 2012 | Hotpoint First Edition WMA22 Front Load...
Drive belt snapped what is the cause
There are a couple of reasons for belt snapping.
1-Main drum bearings siezed, thereby caosing excessive friction, and belt to snap.
2-Motor siezed up, again causing excessive frictional wear on belt.
Try spinning drum by hand, it should be free, with no noise from it, if it runbles or feels rough, then drum bearings have failed.
3- Drum pulley loose or cracked, check the pulley for cracks or fractures.
Dec 23, 2010 | Hotpoint First Edition WMA22 Front Load...
One of the 3 brackets inside the drum of my machine has come loose. How do I resolve this? Any ideas appreciated. Thanks Mrs. Watson
Pull the lifter towards you to remove it, obtain a new one from Hotpoint, and push and slide the new one forward into place, you should feel it click into place.
Sep 13, 2010 | Hotpoint First Edition WMA22 Front Load...
I have a hotpoint wma22. problem with it does not spin.The belt is ok .
+I would remove the motor and check the brushes for wear.
If they are less than 3 or 4mm long, thet need replacing.
If brushes o/k, then it is probably a control module fault.
I am of course assuming that the washer has drained the water out, or it will not spin.
Jan 12, 2010 | Hotpoint First Edition WMA22 Front Load...
Hotpoint WT540 Bearing Change. I have got the drum out but I am having problems spliting the drum. Is it bonded or are there any tricks I can use to split the drum without destroying it
If there are no visible screws or other obvious means of the 2 drum halves being joined together, then it is not possible to change the bearings, as it is a one piece drum.
Current models are one piece, earlier models had screws securing the drum halves together,
Hope this helps..
Jan 11, 2010 | Hotpoint First Edition FEW10P Front Load...
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint First Edition WMA22 Front Load...
Hello there, I am trying to source a drum bearing for a Hotpoint WMA22 washing machine. Is a WMA22P bearing suitable? Only I have found two sizes advertised for a WMA22P (30 & 35 mm) Thanks, Clive.
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Oct 05, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Sep 27, 2008 | Hotpoint Washing Machines
WMA22- Machine has started making lot of noise.
Sounds lika main drum bearing problem
As it is only 6 months old, then you should contact service agent.as it will still be under guarantee.
Aug 02, 2008 | Hotpoint First Edition WMA22 Front Load...
Washing Machines Logo
594 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
