84 chev 1/2 ton pk trk with lp & gasoline system won't start
  • 1450 Answers
SOURCE: how to remove auto hubs on 84 4wheel drive pu
there should be 5 or 6 allen bolts around hub. remove these and cover will come off then there is a snap ring on axle and one around the edge of hub remove thes and will slide off
Posted on Jan 06, 2009
  • 79 Answers
SOURCE: replace fuel pump on 1988 chev 1/2 ton p/u
disconnect the battery,drop the gas tank,disconnect the hoses and wiring harness,get tank out in front of you,take out sending unit take off pump,replace is opposite of removal
Posted on Mar 22, 2009
  • 680 Answers
SOURCE: 84 chevy 4 wheel drive auto hub removial
Remove the outer hub, (MANUAL OR AUTOLOCKING?) Check for a large snap ring. Insert two of the screws back in a few turns and slide the center out. Remove the large nut. Usually another snap ring, and then another large nut. (Caliper and wheel first).
Posted on Mar 01, 2010
  • 138 Answers
SOURCE: . Install A4Tech PK-636A/PK-636MA/PK-835/PK-935 Ca...
click here
to download driver for your web cam (win 7 compatibility) from official site of A4tech.
since it is rar file you need software like 7zip or winrar
follow the instructions below for proper installation
  • Save driver somewhere where you will remember after download . i recommend that you save it on your desktop , so it will be easy to find .
  • After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any webcam driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
  • After the original driver has been removed , open the downloaded file
  • Follow the on-screen instructions .
  • When it's successfully installed , please restart your computer .
  • After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
i hope that this will work
Posted on Jun 14, 2010
SOURCE: 4x4 fuse on 1991 chev 1/2 ton keeps blowing..Why?
You might have a short in your wiring some where from the actuator back to where the wires go through the cab .could have been rubbing on something to cause this . just a thought
Posted on Sep 22, 2010
Is SAE 5W - 30 ok for my old Jeep and Cheyenne...
Its probably ok but I would recommend 10w30 for anything with more than 100,000 miles on the odometer.
Also, 5w30 works better in colder temps, the first number is the "cold thickness" and the second number is the "hot thickness". The bigger the number the thicker the oil in basic terms.
Apr 04, 2016 | 1997 Jeep Grand Cherokee
Where is the fuse for the right tail light located and what is it labeled?
It's marked LP PK R 15 amp , it's located in the instrument panel fuse box . IP Fuse Block
Under the right side of the IP, near the rear of the IP compartment
LP PK R Fuse 15
15 A
Remote Function Actuator (RFA) Module, License Lamps, Tail/Stop Lamps, Tail/Signal Lamps, RH Side Marker Lamps, RH Front Park/Turn Signal Lamp
Apr 27, 2015 | 2000 Buick Park Avenue
Starts and dies right away, intermittent fuel guage
If initial indications sound like a buoy gasoline and extenders and gasoline injection system in the compartments, the problem is in the power feeder wires or in the Bawa-jee or in the combustion chambers of electricity and gasoline. This prevented Mator that it does not appear any kind of Leak of oil and water.
So observed in the case of operating the initial car exhaust fumes if the color was black injection system maintenance problem but if the sky was the color of this is evidence that the oil spill to the combustion chambers.
4db5eaba-57dd-4e28-a8fb-64a64e8b9983.jpg 351746a9-e081-48bb-a651-721784cf6eed.jpg
Feb 26, 2014 | 2002 GMC Sierra 1500
Trk won't pass inspection. It has the code PO420. catalys system below efficieny.
My father's 99 Suburban had a similar code for Bank 2(passenger side).Change the O2 sensors before and after the catalytic converter for the driver's side(cylinders 1-3-5-7).All four sensors are in the front section of the exhaust,just follow the pipe from the driver's side manifold to find the correct sensors.
Dec 08, 2012 | 1999 Chevrolet Silverado 1500
1988 chev suburban engine dies when putting into drive or reverse
At this website I found all
complete guide,much better language, complete detail in 800+ pages, ..and they also have live chat for instant help feature
Mar 03, 2018 | 1988 Chevrolet Suburban
I'm new to MP3 players and am having trouble with naming albums I am downloading to the internal memory of my Sansa Fuse. Some of them start with 8-9 numbers before the title when I look at them at the...
right click on the mp3 file...(c drive or sansa) properties/ general here is where you can also name the track.....summary is where you can fully name the track,year,track number,album,genre...your track name can look like this (name of trk - trk # - lp name - artist) or (artist - lp name - trk # - trk name)any way that suits you can also break down in folder like for instance lets call this folder coldplay in this folder we have three lps (coldplay, coldplay live and coldplay again)
May 23, 2010 | SanDisk Sansa Fuse MP3 Player
1988 Chev half ton kills battery. Put in new battery and starts right away. Ran it for about 20min then shut it off. Tried to restart and battery is completely dead. Needs boost to restart.
Have your starting system checked for starter draw.If the starter is drawing to many amps it will draw the battery down very quickly.Also have your charging system load tested to make sure the alternator is charging properly.Hope this helps.Good luck.
Mar 16, 2010 | 1988 Chevrolet C1500
Jan 13, 2009 | 1991 Chevrolet C/K 2500
97 chev truck
I think its a good idea to replace the engine.
Jun 17, 2008 | 1997 Chevrolet K1500
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
