Question about Panasonic Microwave Ovens
Mcrowave oven NN_ST657S.brand new.took out of box plugged in and tray will not stop rotating.
  • Panasonic Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
It should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If you don't have your manual, you can get it at Panasonic's Australian site here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
Panasonic nn t945sfx
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Dec 05, 2013 | Microwave Ovens
Panasonic Inverter Manual
go please to www.fitness.manualsonline.com or www.retrevo.com and download free.
God bless you
Oct 31, 2013 | Microwave Ovens
Glass tray of my microwave oven Panasonic model NN-SD577M is not rotating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 06, 2011 | Microwave Ovens
The microwave turning table hasitantly rotates and stops. the Model number is NN-S951BF - manufactures in April 2001
It may be that the wheels on the support may be a bit dry. You can use a tiny amount of cooking spray or cooking oil to try to lube it.
Petroleum-based lubricants are not advised in food preparation areas such as the inside of the oven.
You'll want to be sure the support and the floor of the oven are very clean before applying the spray.
If that fixes it, great, but if it fails again in a short time, then the support needs to be replaced.
May 29, 2010 | Panasonic NN-S950BA Microwave Oven
NN-S951BF after it starts it has troublr truning
May 29, 2010 | Panasonic Microwave Ovens
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Panasonic microwave nn-s963bf making grinding noise
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Mar 04, 2009 | Panasonic NN-S963BF Microwave Oven
Panasonic inverter model no NN-S540
You can download your owner's manual here.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jul 12, 2008 | Panasonic NN-S540 Microwave Oven
Microwave oven NN-S573
The usual cause is the tray motor assembly, or the power supply that feeds it. These parts are available from the parts rep for Panasonic. Contact Panasonic for details.
There are serious safety issues when servicing microwave ovens. I suggest to have the oven professionaly serviced by an experienced service tech for these products.
Jerry G.
Apr 17, 2008 | Panasonic NN-S753 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
