What else do you think it could be but a corrupt file? Two programs say the file is corrupt....the file is corrupt. Have them resend the file if you can, otherwise it's lost.
What version of Reader are you using? Some newer .pdf files ure using formatting codes that older versions of Reader cannot decipher and thus fail to open. Older files will still read regardless of the version of reader. Ensure you have the most recent version of Reader and try again.
There could be several reasons why you're unable to save a PDF file in PDF or DOC format. Some possible causes include:
The file is open in another program: Make sure the PDF file is not open in another program and try saving it again.
The file is locked or protected: Some PDF files may be locked or protected, which can prevent them from being edited or saved.
The file is corrupted: Sometimes files can become corrupted, which can prevent them from being saved. Try opening the file in a different PDF viewer, and if it opens without issue, then the problem might be with the viewer you were using.
Insufficient permissions: Make sure that you have permission to save the file in the location where you are trying to save it.
The drive or folder where you're trying to save the file is full: Make sure the drive or folder where you're trying to save the file has enough free space.
Problem with the software: It could be a problem with the software you're using to open and save the file. Try using a different PDF viewer or word processing software to open and save the file.
It's difficult to say exactly what the problem is without more information, but by checking these possible causes, you may be able to identify and fix the issue.
Download pdf file from your email then, save to USB flash drive. Install pdf installer. download from google and install. After installing try to insert ur USB flash drive and open your pdf file.
may help to indicate what happens when you try to open pdf files however, try to clear browsing history and cookies and make sure you have the latest acrobat reader installed and check that your PDF files are associated and set to be opened by default using acrobat reader
