Question about ASUS P5RD1-VM Motherboard
Sata hdd detected but problem with booting&installation
I have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration"
Posted on Jul 24, 2008
    President:
  • 2,351 Answers
When using a single SATA drive you need to set the Serial ATA Controller to [Enable] & set the M1573 RAID Function to [Disable] Page 2-24 in the manual.
Posted on Jun 30, 2008
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
How can i fix my seagate HDD,it wont detect in bios boot up..
Make sure it is connected to power and SATA, try a different SATA connector on your motherboard, there are probably 4 different connectors. Also make sure that the SATA controller is set to "NON RAID" mode in bios.
You need to go into BIOS to change these settings, If you don't know how to do it Give me your motherboard details (model no makers name)and I'll write you out a walkthrough to set the bios up properly for your drive
Jan 25, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Raid problem
Windows XP does not support SATA you need to load the SATA drivers from the motherboard manuf. You should have a cd for RAID/SATA drivers. When you boot off the XP CD it give you an option to load third party drivers watch at the bottom of the screen. When you see this message you can insert the CD that contains the drivers it is looking for the you should be able to load Windows XP.
I hope this help. Please rate.
Feb 18, 2009 | ASUS P5RD1-VM Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
596 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
