Question about LG Televison & Video
I have an LG 44inch DLP TV. Ihave had it for about 5 years. Recently the lamp blew and I fitted a replacement. After switching back on, everything was fine for twenty minutes, Then thin white vertical stripes appeared across the screen and would not go away. Can you tell me what needs to be done Please.
  • 5 more comments
  • Tallawong Jul 06, 2008
    I have tried the cleaning connections idea. This did not work. After 40 minutes, the pin stripes overlaying the picture returned.
    I have used different signal cables, and a different signal source. The picture is as you have described, like looking at a picture through white prison bars. But this fault only happens after the set has been on for some time, which may indicate a fault thatis of a thermal nature.
    This has been done at the very start of the fault investigation.
    I have tried cleaning all cables and connections, to no avail.
    I am convinced that this is an internal problem.
    The lamp that I have replaced is an exact replica of the original lamp in every respect, including the manufacturer. I am an Electrician by profession, so I do have some idea of what I am doing, when it comes to replaceing lamps.
  • Tallawong Jul 07, 2008
    The lamp is fine. Tell me more about this convergence theory.
  • Tallawong Jul 08, 2008
    There is nothing wrong with the lamp or the power supply.
  • LG Master
  • 13,433 Answers
Contact LG for service. we can't perform miracles over the internet.
Posted on Jul 08, 2008
    President:
  • 1,257 Answers
Just check if the lamp is good and don't have any problem and then go for power checkup..it might be because of bad power..
Posted on Jul 07, 2008
  • LG Master
  • 19,396 Answers
Check if the lamp you mounted is blown again.
The most likely is that the small pcb that power up the lamp is blown.
You need to test the board with a multimeter, If the pcb is fine (I doubt from description), you may just need to perform a service convergence procedure.
Posted on Jul 06, 2008
  • Ginko
    Ginko Jul 07, 2008
    Convergence setup is not a theory it is a service
    procedure that repairman ordinarily do whenever there is a convergence problem, you need a service remote (original remote is enough on some model) and to perform the service procedure illustrated on the service manual for your model.
    Service procedure should not be used unless you know what you are doing, as in service mode you can cause serious problem to your tv.
    If your TV had been fine for twenty minutes or so before giving you the problem, this means it is not a setup problem.
    Something had just blown after 20 minutes, could be some component on the board that control the lamp or some IC on main board has blown.
    On las pages of your owner manual you will find LG phone number to call to have your TV serviced.
    Scholar:
  • 135 Answers
Sir
i think the lamp u replaced is not compatible with your tv. this is the reason behind produceing stray capactance which disrupts the cell column..
do chek for an update in the lamp.
  • Harrish Mugundhan Jul 06, 2008
    sir i read this article
    "I've had the set in the shop 3 times now for this problem. Originally the set didn't have this problem. I had a small white line, that I really didn't notice unless the TV was just turning on and powering up... should have just let it be, but I figured it was the start of something worse so I called LG for service. The Tech changed out a bulb, then a circuit board or something or other, and then everything inside the unit. What are my options now? LG has sent out techs but they look at the TV when it's on a program like the news or the weather channel. I don't have problems with bright programming and the Techs are reporting to LG that their aren't any problems with my set. I'm at a loss here""
    NOTE : ITS BETTER TO CALL LG TECHS TO ATTEND THE PROB
  • 796 Answers
Try reseating all of the cables and connectors. This is a communication problem between the processing board and the display or the display is bad.
    Genius:
  • 2,035 Answers
Remove the lamp and clean the lamp and make sure there is no dust on the lamp install it back.....................
  • Anand Kumar
    Anand Kumar Jul 13, 2008
    If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
    http://servicemanuals.vstore.ca/
    Guru:
  • 1,894 Answers
Is this appear like think solid vertical bars??
is it appear like the whole picture running behind the bars??
  • 2 more comments
  • dewan nafees ahmed Jul 06, 2008
    if yes then you you actually need any one of the following options
    • a different connector that brings in the signal
    • a different signal cable.. if these 2 don't work then you need
    • a color wheel position adjustment
  • dewan nafees ahmed Jul 08, 2008
    this will be a convergence problem i guess.. have you replced the convergenc ICs?
    also are the lines black in color or in various colors?
    for example if yopu see blue lines
    do as said here
    the lines are most likely the panel which isnt cheap
    the blue speckles are just a voltage adj. on the y sistain if you feel confident enough you could try this yourself(though expensive equipment is usually required i do without). what you would have to do is take off the back panel if you have a stand put it back on that. easier to work on. then plug it. BE CAREFUL not to touch anything inside!!! from the back you will see a board on the left side on that board will be a small board attached vertically it will have a gray screw attached(very small). with the tv on you adj. the screw until the blue goes away(a little does alot).
    Sergeant:
    Champion:
  • 417 Answers
Tyr Removing the Lap And Cleaning the Terminals Which The Lamp Plugs Into
Posted on Jul 05, 2008
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Lamp timer near 10K
just go through the manual it will guide you to solve your problem..........
Aug 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
The picture has recently become darker than usual, what can be the problem?
The tv projection lamp.It is been inside the tv like about 1 1/2 or 2 years?Tv been on and watches like 4 or 5 daily?Yes,than the tv projection life are comming to an end.Replaced a new tv projection lamp.
Dec 24, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
I have had this Samsung DLP HL-P 4663W for about 3 years now.
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    LG RU52SZ61D lamp Reset?
    Press and hold ENTER or OK on front of the TV and press MUTE on remote at the same time for 5 to 10 seconds. The lamp reset box will pop up you can then reset lamp timer.
    Aug 14, 2009 | LG 52SX4D 52" HDTV
    LG DLP Suspected Faulty Bulb... how to be sure?
    First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
    Aug 06, 2009 | LG Televison & Video
    Samsung HL-S5087W shuts off.
    the number is 3409-000178
    should cost less then $5
    Dec 29, 2008 | Samsung DLP HL-P5663W 56" TV
    I have a LG 52SZ8R-TB DLP TV. I have recently had to replace the lamp. I ordered this through a certified LG repairer. Upon fitting the new lamp the TV appears to not be light enough. It is that dark I...
    We had the same problem. One place changed the lamp but they couldnt work out why it was red and lots of shadows. Next mob said that it was the component so they replaced that. From the 28/4 till end of Oct, the TV has now switched itself off and wont come back on. Both places say its the lamp - however I cant see how in 6mths it would run out again. The people who replaced the lamp dont want to help, just said they will put in a new one at $521. This TV has cost us so far $1100 in repairs and it's only 3 yrs old. Not happy. The DVD recorder broke within the first year, the set top box broke in the 2nd yr and the surround system blew up (yes smoke appeared and we were lucky we were home) on the 13th month. Mind you our LG comp screen also shut down on the 13th month. Never again will I buy LG
    Jul 14, 2008 | Televison & Video
    RCA DLP HD50LPW166 Works fine for 15sec
    Same Problem here. After some investigating and speaking with one Lamp supplier they told me to replace the Lamp Ballast first (this is mine EUC 120 P/H11 9137 008 09405). I found one on Ebay. Since this may also wear out the bulb, I may have to replace that also. If I can get my TV working (HD50LPW166YX6) for around $150.00 for both, I'll be happy even if i get only 6 month of use out of it. Did I mention the TV was free? :o) Hope this helps.
    Mar 22, 2008 | Televison & Video
    Televison & Video Logo
    42 people viewed this question
    Computer Repairing
    Computer Repairing
