Question about Refrigerators
Best temperture to keep up right freezer and a different refrigerator
What is the best temperature to keep refrigerator and up right freezer set on?
  • 828 Answers
Freezer temperature for storage depends on the type of product you are putting into it. Ice Cream as an example must be kept below zero °F as also with bread dough type products. Refrigerator temperatures are best kept below 41°F.
Posted on Jun 30, 2008
Seeking normal temperture range for 10 cubic foot refrigerator
Refrigerator temperatures should be between 34 to 38 for good cooling. Freezer temps should be from 0-15 to keep ice cream fairly hard
Mar 25, 2014 | Jenn-Air JCD2290HES Side by Side...
Set temperture
Typical settings for a refrigerator / freezer:
Fresh food compartment is around 35 - 36 degrees F,
Freezer compartment is anywhere between -10 and 0 degrees F.
Jun 11, 2013 | Refrigerators
What temperature should a refrigerator be
there are different levels they do not indicate temperature but level 4 I find is the best setting .If you have a side vy side It helps to keep the freezer well stocked .this increases the temperature for the fridge side.
Jul 27, 2012 | Whirlpool Refrigerators
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Bottom freezer can't regulate the temperture
Hi, your bottom freezer not regulating it's temperature means you have a faulty thermostat which actually regulates the temperature of the freezer.
You have to replace the thermostat to solve the problem.
Take care
Jul 24, 2010 | Maytag MFD2560HES Bottom Freezer French...
Original motherboard
Hi, When i change motherboard that got fried I change also the Temperture sensor Number: WR55X10087
it is under the cover on the right side
Jan 07, 2010 | GE PTS25LHP Top Freezer Refrigerator
Cannot keep fridge at proper temperture,keep trying different settings
The fridge section runs off of the freezer..
Set the freezer close to recommended factory setting.. If you want things a little colder - go a little higher - etc..
Set the fridge setting close to recommended factory setting..
The recommended settings are usually pretty good and help the fridge run at peek performance..
Any change in settings will take at least 12 hours or more to take effect..
Sep 29, 2009 | Hotpoint Refrigerators
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Best temperture
freezer should be at -18 to -22 degC and fridge at +4 to +6 degC
Nov 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
