Question about Nokia 1110 Cellular Phone
POWER PROBLEM WHEN I SWITCH ON THE PHONE THE PHONE ITSELF BECOMES HOT AND LATER SIGNALING (EMPTY BATTERY
    Sergeant:
  • 234 Answers
I think you are using duplicate battery! please change your battery! buy an original battery!
Posted on Jun 30, 2008
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
97 Pontiac grand am - no power to 4 underhood fuses (f/p injector, ign mod, erls, abs) i have figured out those 4 fuses are powered by a thicker pink wire not from the battery. Any insight where that pink...
Not sure about the pink wire but these fuses get their power from the fuse box itself. The fuse box is fed directly from the battery 12V hot signal by a red wire maybe your red wire has turned pink over time. That wire comes from the battery, a jumper post from the battery, the starter wire, or the back of the alternator depending on the model of the GM. i believe your Grand-Am has the fuse box powered directly from the positive post on the battery via the battery cable. The fuse box gets also gets an input from the ignition switch so that when the switch is in the on position the bus bar containing "ignition on" voltage becomes hot with battery voltage. one side of the fuse comes from this voltage bus bar and the other side of the fuse goes to the component.
May 26, 2014 | Cars & Trucks
Batteries and phone very hot
There is a short in the phone that causes a high rate of battery discharge resulting in a overheating battery.
This cell phone is faulty and I suggest you get a new cell phone.
May 21, 2013 | Nokia 5130 Cell Phones
I have 2000 Kia spectra. It shut off while ideling. I have changed the fuel pump and checked fuses/relays. We used a insulated wire and ran it from the battery to the fuel pump relay fuse socket in the...
You need to troubleshoot the relay and terminals. First try a different relay. Another relay in your car may be same part number relay as you pump relay, so check for that. Swap in a known good relay and try it.
If no help, look at relay. Is it 4 terminal or 5 terminal? If 4 terminal, easier to check. One terminal will be your power source, and hot at all times, so check for that-use your jumper wire (if no testlight or voltmeter), stick end in terminal and just touch metal, looking for spark indicating power. If no terminal has power, maybe only hot with key on, so turn key on and check for power. If no power, the feed from battery to fuse block is lost. If you have one power source, another terminal will be to the pump, the one you turned pump on with. Terminals 3 and 4 will be the signaling source to turn relay on through coil side of relay, and a terminal to ground, also on the coil side of relay. If you have constant power on one terminal, check for the signaling power. When the car is cranking over, the signal terminal should be hot-the signal will be coming from engine computer. So when cranking, relay socket should have two hot terminals. If you don't have two, you're right, relay is not getting correct power to the fuse block. BTW, don't use jumper wire to check for signaling source, use a testlight. Don't want to cause spark from computer wire.
What is EGI? Not familiar with that.
Jan 07, 2013 | 2000 Kia Spectra
My LG phone when battery is placed it switches ON by itself and the button becomes hot what can i do?
YOUR MOBILE CHARGING IC HAVE PROBLEM . PLEASE GO TO CUSTOMER CARE TO REPLACE IT
Sep 21, 2012 | Cell Phones
The running lights on my 1979 jeep cj wont work, brake lights and headlights do work. how do i fix this ?
Good news is that you don't have any control modules etc to deal with. Check for power using a test light. Start by checking the actual bulb sockets and all fuses. Make sure the socket grounds are good
(if there is power at the center contact for a bulb but the bulb does not come on the ground is bad).
Also check the light switch itself to make sure power is coming out to the wire for those lights.
An easy way to find which wire from the switch is for those lights is to connect battery power to the hot wire of any of the running light bulbs and then check the connector at the switch to see what becomes hot (has power) that did not before you did that. No power there tells you that there is a disconnect somewhere in the harness. Trace the wire using the test light as a probe to see where the power stops. If that same wire isn't hot when connected to the switch with the lights on, likely the switch itself is bad. (test done with "test" power not connected to the harness)
Never use this test method in any newer vehicle or you can damage control modules.
Any questions about what you find, just ask.
Mar 23, 2011 | Jeep CJ7 Cars & Trucks
Nokia 3110 calling time battery empty and switch off
when i power on the mobile show battery empty after show nokia icon then mobile power off
Oct 14, 2010 | Nokia 3110 Cellular Phone
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
The PDA turn off and it will turn back on immediately later ......
I get much the same, but it comes and goes. For a week or two it will behave itself, then goes pop for a month or three! Do you find if you have external power (cradle or USB) that it will switch off? I also find that if I switch it off from battery power, it will switch itself back on, but then the power switch is ineffective for 6 or 7 seconds. Then you can switch it off, only to repeat the whole excercise again (and again, and again, and again...)
Sep 08, 2005 | Toshiba e740 Pocket PC
Nokia 1110 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
