Hi I have a strange problem to. Suddenly I cannot access my USB memory stick. When I plug it in it is recognized, and the drive letter is assigned to it. But when I try to open or explore it in windows commander I get an error Drive not found & then I tried it in windows explorer the drive letter comes up & when i try to open it, it comes up with Disk is not formatted do you want to format it now. It worked fine before I reformatted my PC I have tried it in my other PC & it will not work there either or on the lap top & it use to work fine on all 3 pc & of cause I put all my data & photos on it I'm using WinXP pro SP2. I did used MSCONFIG to try & diagnose the problem but did not work Anyone have any idea what could cause this, or where else can I get HELP? For I need my info of it. Thanks
  • Wendy Ferguson Jul 01, 2008
    I update my viruse definition before scanning and disable system restore.
    & there is no difference my USB will still not work
  • 4,889 Answers
It looks like the stick needs to be formatted. The file system is probably corrupted and a format should fix it. Also while formatting choose FAT32 as the file system coz it is more reliable and remains intact for a longer period.Let me know if it worked.
Regards,
Sai.
Posted on Jun 30, 2008
    Genius:
  • 2,785 Answers
Plz check your pc for viruses. plz update your viruse definition before scanning and disable your system restore.
plz post your findings
I have windows 7 and wont to use flash drive for hard drive and memory storage
Just plug it in and it should be recognized by Windows and assigned a drive letter.
Jul 12, 2014 | Lexar Electronics - Others
I need to know to download my pictures to PC
This depends on you PC and its capabilities.
OPTION A - Need the Sony USB Cable
The Sony Cybershot comes with a USB cable. You connect the cable to your camera and then to your PC USB port. Your PC should recognize the device as a camera or a drive and it will assign it a drive letter (similar to a hard drive). You can access the contents (pictures or videos) directly from the mounted drive, because it will treat your camera like a hard drive. Just make sure you hard drive
OPTION B - No Sony USB Cable If your computer has a multimedia drive, you can remove the memory stick from your camera (hatch door underneath camera) and stick into one of the slots on the multimedia drive on your PC. All computers come with multimedia drives and even some monitors have them built it. If you do not have one, I suggest you buy an external one; they are not expensive. Once you put the memory stick in the drive it will recognize it and a windows explorer window should automatically appear.
Let me know if this helps. Please rate and leave feedback.
Jan 06, 2011 | Sony Cybershot DSCW310 Digital Camera
VAIO desktop does not recognize Sandisk flash drive
Most probably you have a drive letter conflict? If so, right click "My computer" choose "Manage" and locate "Disk management" - here, in the middle lower panel, you should be able to find your usb-memory stick, right click it and assign it a drive letter that you're sure is not in use.
Jun 01, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
HOW DO I USE THE MEMORY STICK?
memory sticks are plug and play devices.
simply plug in the stick on the usb port and the device would get automatically detected. it would be visible in the my computer window.
you can use it for storing your data.
Feb 02, 2010 | Sony 512MB Micro Vault Ultra Mini USB 2.0...
How do you copy on to a memory stik
when you insert the stick it is assigned a drive letter. In windows explorer make a note of the drive letter. Right click on what you want to copy then send to that drive.
Nov 08, 2009 | Acer Aspire 5610-4648 Notebook
Music to my easyram 2gb stick 4rom internet.
There are several ways to transfer music into your memory card. Please read the options below:
1. Main thing to do, download music to your computer using a program (i.e. Lime Wire)
2. Save the downloaded music to your computer where you can easily find it.
3. You need a USB card reader where you can insert your memory card.
4. Insert the USB card reader while the memory card is inside of it.
5. Make sure that the computer will recognize your memory card and verify the drive letter that will be assigned to it. (i.e. D:)
6. Locate the music and then right-click on it and then select Send To.
7. Select the drive letter of your memory card (D:) and the music will be transferred to it.
*Another thing*
1. Open the driver letter (D:) assigned to your memory card by double-clicking it.
2. Highlight all the music that you would like to transfer.
3. Place the mouse pointer to the selected music and hold down the left-click button of the mouse and then drag it over to the memory card.
Mar 26, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Drive No Longer Appears as an Available/Accessible Drive
goto disk management - right click and choose assign/change drive letter
Mar 18, 2009 | Electronics - Others
Unable to access thumbdrive
It is possible that windows is trying to assign a drive letter to the thumb drive that is already assigned to another drive. You will need to go to Disk Management to see if the thumbdrive is showing up there and then try to assign it a drive letter.
Feb 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Disk drive not detected
When the drive is not recognized, try going to start->control panel->administrative tools->computer management->disk management and see if the drive is recognized by it, if so try assigning a drive letter then exploring it
Nov 17, 2008 | Dell Latitude D600 Notebook
Unable to access files on SONY memory stick
Hello. Windows will automatically give it the next drive letter available whenever you install it on a computer. That being said, it sounds like the stick itself is bad. It won't work on any computer so that rules out a computer issue. Since you cannot access it once it recognizes the drive, the media has become corrupted or gone bad. Try right clicking on the drive and formatting it but if that doesn't work, I'm afraid its toast.
Jul 02, 2007 | AOpen AX4B Pro-533 (91.88M10.102)...
Computers & Internet Logo
David Payne
David Payne
