Question about Zanussi Refrigerators
I have a zanussi fridge freezer. I have had it for a number of years and it has now stopped defrosting automatically and I have had to defrost it twice in a month as huge chunks of ice are forming in both the fridge and freezer. It gets so bad that I can't open the freezer draws! Is this a sign it is at the end of its life?
  • 828 Answers
It means that the defrost system has a fault which IS a repairable item. Defrost systems have three main components; a timer that starts the defrost process, heater which defrosts the cooling coils, and defrost termination switch which shuts down the heater when the temperature is reached where all ice is gone.
Posted on Jun 30, 2008
Where is the defrost timer in a Zanussi ZNB323W/ Electrolux/ ZNB323S fridge-freezer ? I can't find it?
The timer box is located in the compressor compartment to connect the timer to the electrical components which
defrost the battery evaporator (defrosting heater, thermal switches).
Dado
Sep 24, 2015 | Zanussi & Electrolux Fridge Freezer Handle...
Zanussi zrb324nwo fridge not chilling.freezer forming ice/frost
Sounds like a defrost component Dave Start by turning the defrost timer slowly clockwise until refrigerator stops running and then stop. Open freezer and look and feel. Is defrost beginning to melt the ice?
Fridge Freezer Timer
Genuine spare part for select models of Electrolux, Faure, Zanussi and Zoppas fridge freezers.
Defrost Thermostat
or the
Fridge Freezer Defrost Heater
If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 22, 2014 | Refrigerators
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Myfreezer works fine but my fridge only works for about 15 days and then stops working,when i unplug the fridge and let it defrost the freezer will work for another 15 days it is a hotpoint ff4dx fridge...
This is telling you that you have an automatic defrost problem.
Before I go on here the model number you passed appears to be a UK model.
The problem can be:
1. The defrost timer / control
2. The 60 deg F defrost bi-metal thermostat
3. Wiring
4. The defrost element.
Some info about the 5 year warranty is on page 11 of the owners manual: http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19506810502_UK.pdf
I do not locate the appliance parts manual for this unit as I am not in the UK.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Refrigerators
Fridge part now working
Hi and welcome to FixYa. I am Kelly.
What your describing is a result of either an automatic defrosting problem or an Air Damper problem.
Here is what you can do to determine if it is a defrost issue or an Air Damper issue.
1. Unplug the unit
2. Empty the freezer section ONLY contents
3. Place a fan blowing into the freezer section for a little over 2 hours. NOTE: This will make a water mess so be prepared.
4. After the manual defrosting session with the fan re-load the freezer contents and plug the unit back in.
5. Check food section temps in about 4 hours.
NORMAL temps you have an automatic defrost problem
WARM temps you have an Air Damper Problem.
Either of the above will require further troubleshooting or service. At least you will know where to start or... what to tell a service person.
Kelly
Apr 13, 2010 | Zanussi ZEBF250W Bottom Freezer...
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Jun 12, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
238 people viewed this question
Top Zanussi Refrigerators Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
