Posted on Dec 12, 2010
6A81 Printer error has occurred. Turn off power and then back on again. If problem persists see the manual. I have tried this with the same result. ( I had a piece of paper got jammed... have released it but don't know why I am still getting this message.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9316
Points
16
agus azhar
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 31, 2013
agus azhar
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9386
Points
5
Klo printer canon ix6560 mengalami lampu merahnya kedap kidip dan kluar code 6a81 error
  • nanda saputra
    nanda saputra Jan 22, 2014
    buang aja printer tu..
  • nanda saputra
    udah nggak ada gunanya lagi goblok !!!!
Anonymous
Level 1:
  • Posted on Apr 15, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9316
Points
0
6a81 canon collar print problm calme 9951099426
nanda saputra
Level 1:
New Friend:
  • Posted on Jan 22, 2014
nanda saputra
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9316
Points
  • nanda saputra
    so,, what the solutions for error 6A81 ?
    ******** admin !!
2answers
Print error 6A81 how can i find out wot to do
You did not say what type of printer it is, or if you have checked for a piece of paper stuck somewhere in the printer.
Example of possible solution:
https://www.inkredible.co.uk/canon-error-code-6a81-fixed
Quoting from web page shown, photo not included in quote:
"Canon Error Code 6A81 - Fixed! We recently came across error code 6A81 on our Canon Pixma MG5250 Printer (using PGI-525/CLI-526 range cartridges). The error could also occur on other printers in this range.
The error code is basically caused by an obstruction within the printer, usually a paper jam but could be any foreign body that has found its way into the printer (those with young children will understand!). The obstruction stops the carriage and print head from moving into the correct position when powering up the printer. The print head should come to rest at the right hand side of the carriage and position itself over the waste ink sponges. If the print head is unable to do so, it returns the '6A81' error message.
You can see from the picture, the position of the two waste ink sponges towards the right hand side. The sponges are spring loaded and move backwards and forwards when the printer initialisation occurs upon start up.
The problem in our case was caused by two pieces of torn paper. One at the far right of the printer which was simple to remove, but the other was stuck in a small opening behind the spring mechanism for the waste ink sponges. This was preventing the sponges from being moved freely and seated correctly, which in turn meant that the print head was unable to pass over them and come to rest in the correct position.
To remove the torn paper we turned off the power to the printer (to prevent any damage to the carriage mechanism) and used a pair of tweezers to carefully pull the offending article through the small gap. We missed this hidden piece of paper the first time we checked for obstructions so it's worth shining a torch in and having a good nose around!
Close your printer lid, power on the printer and et voila... Canon error code 6A81 is no more!"
How can I fix an error msg #6A81 on the Pixma mg5320?
Error 6A81 is described here: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
1helpful
2answers
I receive an Error Code 6901 on my MX725 printer, what can I do?
It usually means that it needs to be cleaned.
Take out the cartridges and look to see if there is build up.
That normally causes the error.
5220 quit. says "turn off and on"-no fix. Says "see manual"-no info. Shows "6A81 on top of screen. Error Code?
6A81 means the carriage is blocked by something. Start by checking the following image to verify there are no paper jams.
http://ww2.justanswer.com/uploads/wa94sound/2012-04-25_230949_sdf.png
Reply back and let us know what you find.
Error 6a81
Turn off power, remove power cord and wait 10 minutes, then reconnect power cord and turn unit on, if this does not work then advised to contact canon service centre
1helpful
Je viens de recevoir mon imprimante MG 6150 et lors de la mise sous tension, le message suivant apparait: 6A81 printer error has occurred. Turn off power then back on again. If problem persists, see the...
Bonjour nduvignac
J' essayerais de d?sinstaller puis de r?installer le pilote . D?branche l' imprimante pour ces op?rations , relance ton pc apr?s installation et reconnecte l' imprimante . Si le probl?me persiste , il faut retourner chez le vendeur avec l' appareil et le ticket de caisse .
Cordialement ,
fanaudi .
1helpful
Hello i have a canon printer PIXMA IP4800 i have a problem the massage erorr is : 6A81 Printer error has occurred. Turn off power and then back on again. If problem persists see the...
Please help me I've purchased the pixma iP4800 printer and installed everything do I have to now download softwear so I can lable my DVD's as it's saying the softwears not there??????
My printer Canon MP610 has an error Printer error has occurred. Turn off power then back on again. if problem persists, see the manual.
I see no one has replied. I have the same issue, and the only info is the manual saying contact Canon service.
Trying to do that, they want the serial number which they make way too hard to get. Why can't the online manual provide it?
Error message is this: Error Number : 6A00 A problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem...
Unplug printer power supply from wall or powerstrip. Wait 10 minutes then plug in power supply and turn on printer and try again. If problem persists and it is under warranty contact Canon for repair. Otherwise it might be time to buy a new one.
old marine
old marine
ZJ Limited
ZJ Limited
