Question about Foxconn 865M01-G-6LS, Pentium 4, 865G Chipset, Socket-478, mATX, 400/533/800MHz FSB (MBFX865M01G6LS) Motherboard
Motherboard switch are being shorted and there is sudden shutdown after one minute from boot up.
  • 90 Answers
Hi buddy!
what kind of motherboard you have and ill give you a easiest way how to connect ok thnx.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Jun 30, 2008
My Acer EL1800 suddenly shutdown when try to booting and cant boot again then i pulled power plug and plugged again it can boot but after 2-3 minutes it shutdown again.
1) RESTORE the computer to some Date was working before very good2) Use scanner for antivirus+antimalware+update the windows+Update the Bios FROM your supplier +Chipset update too. and Try again.Of course you can use the diagnostic software that coming with any computer marks, for troubleshooting.God bless you
Jan 29, 2013 | Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Giga g31m-es2l motherboard pc resets after running for several minutes
First check the timing of turnoff then Right Click on Desktop -Properties-Screen Saver-Power Button- Set All NEVER
Jun 08, 2012 | Gigabyte GIGA-BYTE GA-G31M-ES2L Desktop...
Hello the fan of the northbridge of my MS 7125 does not rotate, and when i boot up it lock down on Loading screen
HI. This issue with the NB fan will be a direct result of fan failure. The actual fan motor assembly may be shorted or disabled. This fan should be replaced asap(make sure to check the fan connector for proper connection before replacing the NB fan). Now, concerning your halted boot screen; This will be a direct result of a failed or corrupted OS(Operating System). I would recommend to initiate a system restore by inserting the restoration CD/DVDROM that came with the CPU system, when purchased or delivered. This will totally reinstall the OS and correct all corrupted files that have been affected by this unfortunate virus/worm attack.
Due to the fact that your system will not boot up, you will need to insert the restoration CD/DVDROM into its respective ROM device and shutdown the unit for five minutes. Once the shutdown has occurred, simply, restart your unit and follow the restoration instructions on screen during the hard boot. It may be necessary to self initiate the restoration by booting from the actual ROM device, via f11 or f9 command upon boot screen.
Sep 04, 2011 | MSI K8N Neo4-F Motherboard
My Giga byte board number GA-8VM800M-775 suddenly shutdown after boot display some body can help me?????????????????????
I would say you probably have one of two problems:
You have a hardware issue and you should disconnect all hardware except the hard drive and see if it starts.
You could have a corrupt Windows installation. You'll need to boot from a system disk and run scan disk. How you do it depends on what version of Windows you are running.
Jun 28, 2011 | Intel Motherboard
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Have an acer 5510z notebook Model BL50. I want to know if there is a cmos reset jumper switch anywhere. When I switched it on it functioned for a minute and then everything died except the fan.It seems...
I do not believe the Acers have reset buttons or switches. I have reset the Cmos by removing the cmos battery, shorting the two pins with another cmos plug with the wires connected together. I then powered the motherboard up until the BIOS loaded, but you don't have to, to reset it. I then powered down and removed the shorting plug. I put the motherboard back in the case and rebuilt the laptop. The system booted right up with no password, got into the BIOS and reset the information.
Sep 15, 2009 | Computers & Internet
Sudden Shutdown of PC
This can be on your operating system or either the fan of the processor is bad. You just need to check both of that out.
May 25, 2009 | E-Machines (T2824) PC Desktop
PC not booting when AVERmedia TV tuner card is inserted
Techguru2009: Seems you might have a conflict with your I/O. You need to reset the bios either by loading defaults or just remove the CMOS battery for ten minutes. After start the computer without the pci card. If all is well, then shutdown. insert the card in a different slot on the motherboard. Power up and the bios should recognize the update. Hope this helps.
Jan 28, 2009 | Gateway GM5084 PC Desktop
Sudden Shutdown
Hi, I am Sanja and will try to help you.
Try to remove battery from your motherboard, and power cable from computer case. Leave it for about minute, and then return battery, power cable and try to turn on the PC.
You should have no trouble in identifying battery, it is pretty much standard, if you have more questions please do post them
Regards, Sanja.
Sep 15, 2008 | ASUS P5P800-VM Motherboard
Foxconn 865M01-G-6LS, Pentium 4, 865G Chipset, Socket-478, mATX, 400/533/800MHz FSB (MBFX865M01G6LS) Motherboard Logo
90 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
