Samsung LNS4051 DX makes clicking sounds but will not turn on.
  • Anonymous Apr 13, 2009
    You can also get a new power circuit board from Encompass parts. I found they had one for $91 + shipping.
    Scholar:
  • 56 Answers
First, this is not a projection TV.
Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced. If you are not comfortable replacing components which means using a soldering iron, you can replace the power circuit board, available from discount-merchant.com.
Posted on Jan 03, 2009
Hi my tv sounds like it start but it wont como on i change the power board but still did the same what could it be thanks
Samsung 52" TV Repair - Won't turn on Clicking Sound ...
? 9:37
https://www.youtube.com/watch?v=2WpSJy_kANs
Apr 13, 2012 - Uploaded by Kathy Burton
It makes a clicking sound several times before it turns on, seems to ... Samsung 52" TV Repair - Won't turn on Clicking Sound ...Maybe it took a little longer than that, but I was happy. ... My TVworks like new. ... Samsung No Start / Clicking Repair - 52" LCD HDTV - Duration: 8:26. by clipdan 169,453 views.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and ... hi my tv flashes red and bluebut wont turn on.
Dec 12, 2015 | Televison & Video
Dynex DX-LCD19 TV
Main board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 03, 2014 | Dynex DX-LCD19-09 19 in. LCD TV
1992 mazda protege dx 4 dr won't start. Battery is only 2 months old. Makes a fast ticking sound from inside car similar to turn signal light out.
Hi Robin, As the battery is new and presumably not defective, I think you should suspect the soloniod fitted to the starter motor. If that component has become defective it will give the sound you're reporting. Depending on where you live in the world and the labour charges, you can have the contacter's replaced or the starter motor (if labour charges are high) Regards John
Jun 30, 2012 | Mazda Protege Cars & Trucks
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
Hi,. I own Asus Xonar DX two years ago without problems... I formatted my PC (Win7 x64) yesterday, and now i have sound issues when i use 5.1 feature... The sound turns slow and distorted... I uninstalled...
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 06, 2011 | ASUS Xonar DX Sound Card
My Samsung LNS4051 has sound but no picture. I replaced 2 bulging capacitors (CM807 and 808), and it worked for less than 1 day. The other 4 caps frequently mentioned on this site appear to be good, but...
When you replace obviously bad capacitors (bulging, leaking), make sure you also replace any adjacent similar capacitors even if they look ok because they are almost certainly bad too.
If you find 2 bulging ones in a group of 6, don't skimp, just replace all 6 while you have it open.
Good luck and please post back with how you make out.
Jan 25, 2011 | Televison & Video
Samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Aug 23, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
3,938 people viewed this question
Top Televison & Video Experts
