Question about Palm Treo 650 Handheld
Blocked out my treo650 just turned of the the light of the screen.but i can use it even the screen is dim.can recieve incoming and outgoing calls or can make a text.how can you fix it ..pls help
  • sonjazz Jun 30, 2008
    kibbs.... you solved my problem! thanks a lot..i did it and its gone good !thank you very much kibbs !youre great.thanks again.
    Sergeant:
  • 234 Answers
In phone settings! their is a display settings increases the brightness! and then you use and come
Posted on Jun 30, 2008
Hello, i have philips phone ce0168 i can recieve calls but it wont let me make a call and on the screen said keys locked, can you help me for that please?
On your phone, go to settings - phone settings - select call barring settings - here you will see options such as " Outgoing calls" International calls -incoming calls etc. Check your Outgoing call status and select "DEACTIVATE" assuming that it was activated by mistake or by previous owner to prevent anyone from making outgoing calls.
Hope this helps
Enjoy
Jan 13, 2015 | Philips Lands Phones
How do i retrieve my deleted outgoing and incoming calls
it depends on what carrier you have but if you have verizon here is a solution
1. log on to my verizon from a computer
2. go to recent activity
3. go to drop down tab and select incoming and outgoing calls
4. a list should appear with the numbers dialed and recieved
Apr 11, 2012 | LG Cell Phones
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
My p990i didnt work with outgoing sms. . nothing more help
hi
the solution is quite simple just reach yor service provider and request for the sms settings which you will get for free as an SMS
save the settings and you'll be able to send the SMS, same goes about MMS
cheers
pls rate the solution
Jun 29, 2009 | Sony Ericsson K850i Mobile Phone
I can not send txt from my Motorola W375 i can recieve txt make calls recieve calls but can not send txt i was told 2 change the message centre no. how can i do this?
Somce cell phone carriers can block outgoing texts, separately from incoming texts.. You might want to check with your cell company and see if they accidentally blocked your incoming.
Mar 25, 2009 | Motorola Cell Phones
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
No incoming calls
what you can do is a master reset and master clear on the phone.
May 06, 2008 | Motorola Mobility W375 Cellular Phone
What do i do
go to menu, then to settings and tools,then to phone settings, security, restrict calls, enter unlock code you set, then set both outgoing and incoming calls to '' All" and you should recieve calls from everyone.
Apr 18, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Palm Treo 650 Handheld Logo
63 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
