Question about Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor
The power lamp is blinking orange
Dear all
my SyncMaster 240T now is in trouble.
when I plug the power cord, the power lamp is blinking orange and the video lamp is also blinking green with sound beep.
What is wrong with it?
Please tell me.
Wahyul
wasyafei@yahoo.com
    Scholar:
  • 130 Answers
Make sure it is plugged into a computer with a working video card. If error code is still there you have a main board problem. Who is the manufactorer?
Posted on Jun 30, 2008
What causes a Syncmaster 2253LW monitor to start ok and immediately fade.
The monitor may be failing. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
Once power on the monitor after 20 seconds power off how iam rectifed
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 30, 2014 | Samsung SyncMaster 920NW Monitor
Samsung syncmaster 2220 blinking blue light and no image display
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
hello Gabriel
Could you check your SyncMaster 2233 for me and tell me your findings. If this monitor is connected from your computer and when both switch on, did the led indication lamp from your monitor lit steady green? or this lead indication lamp lit green then turns red?
1. If the led indication lamp lit steady green then there is nothing wrong with the settings, configurations, driver or hardware on your computer. The problem would be the backlight inverter lamp in your monitor is busted. Or it could be the inverter board that supplies high voltage for the backlight inverter lamp that is bad. You can replace the backlight inverter lamp located at the upper and lower part of the monitor with a replacement part you can purchase at shoppejimmy.com. Inverter board repair can be risky if you don't have the skill. Even opening the back cover of your monitor and replace by yourself the inverter lamp is risky too, could inflict more damage. you can bring it to a local professional service man.
2. If the led indication lamp lit green then turns red, then if not the video card the power supply section from your monitor is bad, you can replace polarized capacitor with same value. Just inspect and those with blown or leaking capacitor. You can also check the terminals and solder joints for the 15-pin vga terminal connector where vga cable is connected on your monitor. Resolder the terminals.
3. If the red indication lamp did not lit at all. Power supply section in the monitor is bad. You can check the output voltage from the power supply section. +5VDC is supplied for the main board and +24VDC is for the inverter board. Replace leaking or blown capacitor with same value.
Just remember, this should be done when computer and monitor is turn off
Post back if you have more questions. I am willing to give you assistance.
Feb 10, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
My Samsung Syncmaster 240T stopped working today. I tried turning it on, and it starter emitting a constant short beep once every 2 seconds or so, along with the green Video light blinking every time it...
Your Back light inverter power board has died. The beeping and blinking are caused by the power board repeatedly trying to start up and failing. This is a common failure point of LCD monitors2.gif after a few years of use. The heat build up in the monitor case causes parts called capacitors to blow leading to the power supply short. If you can solder you should be able to do the repair. Go to our web site at:
www.ccl-la.com/badcaps.htm We have pictures of what to look for. Now take the back off of your monitor and replace all of the caps that look like the pictures and you should be back going again. Be sure to use high temp parts, they will be marked 105c. The values you will need to get will be marked on the sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert the new ones be sure to put the polarity stripe going the same direction as the old one comes out. If you have any questions just let me know. If you don't want to do the repair yourself we do offer a repair service for $30 + return shipping2.gif.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 03, 2009 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung 240t
u have to buy a tv tunner card its come intrnal & external just buy and connct to your monitor & enjoy tv in a monitor
Mar 06, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Display doesn't turn on, emits short beeps and blinks lights
Sounds like a low power problem, Check the power supply with a good ohm meter set to DC voltage if voltage is less than 14 v. Replace the supply. DWW
Sep 20, 2007 | Samsung SyncMaster 240 T (Silver) 24" LCD...
Samsung SyncMaster 240T issues
a) set your screen resolution to 1024 x 768 and then b)go to desktop( right click) properties -->settings--->advanced--->monitor---> change the refresh rate to 72Hz or 75Hz.
Feb 21, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung SyncMaster 240 T Monitors
I ordered this: http://cgi.ebay.com/14V-AC-power-adapter-for-Samsung-SyncMaster-240T-LCD_W0QQitemZ260130887919QQihZ016QQcategoryZ86707QQrdZ1QQssPageNameZWD1VQQcmdZViewItem on eBay when my power adapter died, and it worked like a charm.
Oct 06, 2006 | Samsung SyncMaster 240 T (Silver) 24" LCD...
Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor Logo
419 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
