My netgear router has the power light and the tick light flashing and i can not get on line
  • foggydew Jun 30, 2008
    Latoof
    The model no is DG834G the power light and the tick light next to it are alternating power light is Green tick light is orange and are aternating quite fast. hope u can help me
    Regards Foggydew
  • Dave May 11, 2010
    please post the model of the router so I may try to assist you
    Sergeant:
  • 287 Answers
Please check the label on the bottom of the router as there are 4 versions... DG834GvX where X is the Version number.
Did the router ever work or is this a new piece of equipment?
Lets at least do some basics...
Can you log into the router?
To log in type http://192.168.0.1 in the address field of your Internet browser. You should get a pop up asking for a user name and password. the defaults are user = admin nad password = password.
Posted on Jun 30, 2008
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
My tick not coming up on my netgear router
  • That's good that the tick is not on .
  • Because the tick light is a POST ( power on self test )
  • In case if there is a hardware fault in the router that light will come on , and indicate u abt the fault ..
May 14, 2010 | NetGear WGR614 Wireless Router
Netgear router - wont connect
In Netgear routers if the tick light is on that mean there are some issues in the router. Normal by resetting the router to factory default can be solve these issues. Please follow the steps below to reset the router.
1. Locate the reset hole at the back of the router.
2. Press the reset button with the help of pen or a pointed object for 15 seconds.
3. Take out the power cable without releasing the reset button.
4. Plug the power back cable without releasing the reset button.
5. Hold the button for 15 more seconds and then release it.
6. Take out the power and plug it back and check the status.
Regards,
Rashsih Sharma
Mar 25, 2010 | NetGear WGT624 Wireless Router
The tick should only light when you first turn-on and then go off If the test light is not coming on at all and the Router is NOT working, and you CANNOT login to the router
An online user manual is available from here http://kb.netgear.com/app/products/family/a_id/1296
I would do a factory reset - To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 20 seconds, until the Test light begins to blink 2. Release the restore factory settings button, and wait for the router to restart, and for the Test light to turn off.
Mar 24, 2010 | NetGear WGR614 Wireless Router
Power light and internet light flash every few seconds no internet access..
If the powerlight and the internet light is flashing then this is problem with the router or might be with the Power supply, If ur Model no: DG834Gv4 then call netgear to get the replacement for Powersupply(if ur product is under warranty) or else get the replacement of the router
-- but if it is not under warranty
-- then try with different power supply,
-- and if that won't help you
-- go for a new router.
If ur issue will resolve rate this...
Regards
TecKC
Dec 24, 2009 | NetGear DG834G Router
The green power light on my Netgear router type DG834G flashes intermittently and we can''t connect to the internet?
Flashing power light is a sign of a bad router , what we can do to correct this is to reset the router to do this press and hold the reset button of the router for 15 seconds while power is ON and then after that reconfigure the router you can run the setup CD or manually reconfigure it.......
Nov 03, 2009 | NetGear DG834G Router
Netgear tich not lighting up
The Tick light should only come on when the netgear first starts, and when all the checks are complete and OK, it goes out. First, make sure you computer wireless is turned on, Next, go to the lower right of your screen to the system tray where there should be a monitor icon with an"X" on it. Right click and select "View available wireless networks". Select your router name and click "Connect" You should connect and be able to get on the web. If you set up security, select your network and click connect. Type in your KEY and then you should connect to the web.
Jun 11, 2009 | NetGear WGR614 Wireless Router
Netgear wirelss modem tick not lighting
Please note that the tick light turns on only when the router is doing a self test. If it is on then that means the router is either faulty or doing a self test. If the router is working fine then the tick light should be off.
May 18, 2009 | NetGear WGR614 Wireless Router
Power light flashing green
the green power light is flashing green with the orange tick next to it and i cant get any wireless internet through it what do i do please help me
May 15, 2009 | NetGear DG834G Router
Wont connect to internet
You need to reset the router if the lights are flashing. Press the reset button at the back of the router for about 20 seconds then release it. Now unplug the power for 20 mins as well and plug it back in. Make sure your connection is right. PC connected to port 1 and modem to WAN or Internet port.
Dec 17, 2008 | NetGear WGR614 Router
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
