Question about Compaq Presario 5000 PC Desktop
Unable to eject DVD drive.
Am using compaq desktop pc. While trying to use a study material CD in the DVD drive, it got struck and am not able to open the DVD drive using the buton in CPU. Also the DVD drive (G:) is not geting listed in "MY computer". Even in the boot option, its saying that "CD drive not installed". I was able to read/write DVDs before. only after inserting this particular CD, it got struck inside. Do i need to reinstall the Drive. Could someone help in fixing out this issue?
Thanks.
    Genius:
  • 2,785 Answers
Plz open your cabinet and check the power cable and data cable, plz try with another power cable and with another data cable, if the problem is not solved then you have to change your dvd drive
Posted on Jun 30, 2008
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Dvd wont eject
Might be the DVD drive, internally a spring may got struck or heavy dust on the laser reader area. Need to open the DVD drive and clean the dust and replace the parts if needed.
Sep 28, 2013 | Compaq Computers & Internet
Can't eject CD from CD rom
Disassembling may be your only option, if the CD is Broken or jammed. Try rebooting and pushing the DVD rom button at boot. I had a DVD explode, I had to remove the drive and disassembling the DVD rom to remove all the pieces.
Apr 07, 2013 | Acer Aspire Z5700 All-in-One Desktop Pc
Dvd drive won't open
Might have a stuck disc. Use a straightened paper clip in small pin hole of the CD drive to manually eject.
Nov 14, 2012 | HP Compaq Presario SR1920NX PC Desktop
My dvd-writer/cd-writer combo will not open?
look a tiny hole in the front of the CD/DVD drive use a paper clip to pull out the tray, when you have the tray out use the EJECT bottom in the drive to close and wait 3 seconds and press again to open, do this at least 3 times.
Fosg2000
Feb 24, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Where do I find the eject key to eject a cd from my Dell studio laptop?
There should be a button on the DVD/CD drive itself, just push that small button and the tray should eject.
If you can't fine the button double click on "Computer" or "My Computer" highlight the DVD/CD in the list, right click on the DVD/CD and select "eject" from the list.
The tray should now eject.
Regards.
Jan 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Cd rom will not eject
On the eject tray of the cd/dvd drive you will see a small pinhole use a pin and insert into that, the cd drive would eject, ITS A MANUAL EMERGENCY EXIT BUTTON ON ALL CD/DVD DRIVES, INCASE THE CD DRIVE DOESNT EJECT normally as your case here
Aug 27, 2008 | Dell Dimension C521 PC Desktop
Disc drive
Does it eject? If not then its a power problem. If the disc tray does eject and load then it can probably be a lens problem First try to clean the lens with a lens cleaner CD.
http://www.nulime.com/CD-DVD-Radial-Disc-Cleaning-System-laser-Lens-Cleaner-Value-Pack/p207841
If it still doesn't work then its a problem with the lens assembly and it has to be replaced. Good Luck!
Jun 16, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
