Question about Pioneer Car Audio & Video
Hi, i just installed my pioneer head unit into my new astra gsi, but everytime i switch the engine off, the unit resets itself and all of my settings. i used to have this unit in my fiesta and it worked fine, is this an issue with my astra or does it wiring different?
    Master:
  • 726 Answers
Yes the wiring is different on the back of the head unit you have a black (earth) red (power) and yellow (memory) you will have to find you memory in the cars wiring it goes to straight power , also you can join red a yellow together and take it to the positive of the battery but you can only turn the cd player on and off but the actual unit its self .
Posted on Jun 30, 2008
  • chris07551 Jul 17, 2008
    u dont no how to do it if i got a innapropiate i do cds all the time u just cant handle the job so if u dont need our help
HI Guys. I have an Opel Astra 2.2 GSI, the car vibrates when idling and driving. Is it possible that it can have anything to do with the flywheel.
motormounts may b worn or car needs tuneup-change plug wires--coil--distributer cap........causing misfiring---cud hav an injector issue tu doing the same thing---------
Jan 26, 2015 | 1998 Opel Astra 1.8
My pioneer avh-x3500bhs keeps resetting itself
Mine does the same thing, its not a wiring issue as I put a different Pioneer Head Unit in its place and the problem went away. I put it back and the problem returned
Jan 16, 2014 | Pioneer AVH-P4000DVD Monitor
Pioneer head unit in a 2007 Ram 1500 issues!!!
From where did you get the direct 12v and ignition? From where the OEM stereo used to be or did you got it from a different location?
Nov 20, 2013 | Pioneer Car Audio & Video
Looking for a 2.2 ecotec timing chain diagram with pictures
Getting the timing chain back on these engines can be tricky and requires more than just a diagram to get right. Here is how the timing chain should be reinstalled. Keep in mind that this engine can cause damage to the valves if the timing chain has any problems while the engine is running so it may not be a bad idea to setup the timing system as follows and do a compression test to make sure that everything is in order there.
Install the crankshaft sprocket with timing mark at the 5 o'clock position. Lower the timing chain through the opening in the top of the cylinder head. Carefully ensure that the chain goes around both sides of the cylinder block bosses (See 1 & 2 in picture): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412535.gif
Install the intake camshaft sprocket with the INT diamond at the 2 o'clock position. Hand tighten a NEW intake camshaft sprocket bolt. Route the timing chain around the crankshaft sprocket with the matching colored link aligning with the timing mark. Route the timing chain around the intake camshaft sprocket with the uniquely colored link (1) aligning with the INT diamond: http://gsi.xw.gm.com/image_en_us/gif/000/000/466/466558.gif
Install the timing chain tensioner guide through the opening in the top of the cylinder head. Tighten the timing chain tensioner guide bolt to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412160.gif
Install the exhaust camshaft sprocket with the timing chain matching colored link (3) at EXH triangle aligned at the 10 o'clock position: http://gsi.xw.gm.com/image_en_us/gif/000/000/466/466570.gif
Ensure the timing marks and the colored links (1,2,3) are correctly aligned: http://gsi.xw.gm.com/image_en_us/gif/000/002/003/2003412.gif
Use a 24 mm wrench to rotate the camshaft slightly, until exhaust sprocket aligns with the camshaft. Hand tighten the NEW exhaust camshaft sprocket bolt: http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412536.gif
Install the fixed timing chain guide. Tighten the fixed timing chain bolts to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412165.gif
Apply sealant, GM P/N 12378521 (Canadian P/N 88901148) compound to thread and install the timing chain guide bolt access hole plug. Tighten the chain guide plug to 90 N·m (66 lb ft): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412164.gif
Install the timing chain upper guide. Tighten the timing chain upper guide bolts to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412167.gif
Inspect the timing chain tensioner. If the timing chain tensioner, O-ring seal, or washer is damaged, replace the timing chain tensioner. Measure the timing chain tensioner assembly from end to end. A new tensioner should be supplied in the fully compressed non-active state. A tensioner in the compressed state will measure 72 mm (2.83 in) (a) from end to end. A tensioner in the active state will measure 85 mm (3.35 in) (a) from end to end.
****If the timing chain tensioner is not in the compressed state, perform the following steps. Remove the piston assembly from the body of the timing chain tensioner by pulling it out. Set the J 45027-2 (2) into a vise. Install the notch end of the piston assembly into the J 45027-2 (2). Using the J 45027-1 (1), turn the ratchet cylinder into the piston: http://gsi.xw.gm.com/image_en_us/gif/000/000/797/797246.gif
Inspect the bore of the tensioner body for dirt, debris, and damage. If any damage appears, replace the tensioner. Clean dirt or debris out with a lint free cloth. Install the compressed piston assembly back into the timing chain tensioner body until it stops at the bottom of the bore. Do not compress the piston assembly against the bottom of the bore. If the piston assembly is compressed against the bottom of the bore, it will activate the tensioner, which will then need to be reset again. At this point the tensioner should measure approximately 72 mm (2.83 in) (a) from end to end. If the tensioner does not read 72 mm (2.83 in) (a) from end to end repeat the steps required to return it to it's compressed state above.
Install the timing chain tensioner. Tighten the timing chain tensioner to 75 N·m (55 lb ft). Use a suitable tool with a rubber tip on the end. Feed the tool down through the camshaft drive chant to rest on the timing chain. Then give a sharp jolt diagonally downwards to release the tensioner: http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412158.gif
Use a 24 mm wrench to hold the camshaft. Tighten the NEW camshaft bolts to 85 N·m (63 lb ft) plus 30 degrees: http://gsi.xw.gm.com/image_en_us/gif/000/000/630/630311.gif
May 25, 2011 | 2002 Pontiac Grand Am
Pioneer DEH-2150 : CD Ejection switches off the Stereo
hi rolls
when there is no CD in unit hold the source button to turn unit to actual on position (when you insert a CD is it self guided once you push it to a certain point or does it just self guide instantly) if you sort of push it in a bit and unit turns on its because the pioneer function says to itself i need to be on so it will play for you but once you eject the CD the unit says time to turn off the solution i recommended should solve this if not let me know and ill figure out another step
hope i was able to help
Feb 14, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I cant find the fuse
hi there should be a fuse in the power loom. there are no fuses on the unit itself. sounds like you have a faulty unit
mark
www.blueice-electronics.co.uk
Nov 25, 2008 | Pioneer DEH-P8500MP CD Player
Pioneer DEH-1500 installation issues
Get a new unit. The damage was done before the smoke was present.
Jul 28, 2017 | Pioneer DEH-1500 CD Player
My Pioneer DEH-P4700MP keep resetting when car switched off
Did you use a harness to connect the wires?
Could be the power line (red) is connect to the ACC (Accessory) orange line, so every time you switch off the vehicle the power to the stereo is interrupted.
Sep 27, 2008 | Pioneer DEH-P4700MP CD Player
Loud engine noise through speakers
Jadrian - I purchased a DEH-P780MP and have the exact same sound. My suond however increases in pitch throughout the RPM range and is audible when operating the headunit on ACC. I have found this problem to being typical in Checy Sports cars since I can swap this head unit out from my camaro SS into my Mustang Saleen and the sound disappears. The same is true for a swap into my SUV. Never quite figured it out! I think the 12V line from the fusebox or from the battery itself doesn't have "clean" power.
Oct 08, 2007 | Pioneer DEH-P780MP CD Player
Car Audio & Video Logo
89 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
