Question about Rockford Fosgate Car Audio & Video
I have a Rockford Fosgate 1 Farad capacitor, power cap how do i wire it in to my car. i know one side is what about the other side is it or -
  • 726 Answers
Hi there installing a capacitor is at your own risk as they charge up and hold a lot of power if hooked up wrong can give you the shock of your life and blow your sterio and computers to bits i learnt my lesson any way remember to take off positve before installing here is a diagram how to install it,,,, ok the positive goes to the battery and the amp on one side and the other to ground .....take a look at this easy to use diagram i found for you hope all goes well
Posted on Jun 30, 2008
How do i charge it
To charge a capacitor:
connect it to a power source that has less voltage than the capacitor's tolerance.
Wait for it to be balanced with the power source's voltage.
The source must be DC.
Feb 20, 2011 | Rockford Fosgate 1 Farad Capacitor Cpc10...
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
It's beeping when turned on. Why?
I have read that if the polarity is reversed, or the connections are backwards, the Capacitor will beep. If this is not the case, it may need to be replaced.
Looking for a diagram so i can see how to install the installing scosche 500k micro farad and do i have to sauder it.
ok this is an easy one first make sure u have all your wires ran through the car connect a ground to the negative side of the cap then run 12 v power wire and use another piece of power to connect to your amp
Sep 29, 2009 | Rockford Fosgate Car Audio & Video
Mi lights dim everytime mi speakers beat
simple issue means your alternator is not able to supply enough amps to keep the system running properly, recommendation get a capacitor to handle the extra load, it acts like a second battery, when the alternator charges the cap it takes the load off the cap rather then the battery, so the lights and system all run with sufficient power i recommend a 1 to 2 farad capacitor for your system if it is about 800+ watts, you will notice the difference immediately
very good cap
Aug 20, 2009 | Rockford Fosgate Car Audio & Video
Reconnecting two amplifiers adn farad capacitor
run a fused + wire from your battery to the + of the cap ground the - of the cap to a good grounding place on your car run a wire from the + of the cap into a one in two out disburtion block make sre it is a fesud one.then run one wire from each or the two out side of the dis block to each amp then ground both amps to a good ground.what type of amps do you have
Mar 19, 2009 | Kenwood Car Audio & Video
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
Rockford 1 farad capacitor
The 1 farad capacitor is something added to current hungry systems to help keep the supply voltage at the proper operating level.
If your amp does not work after putting one in your system, but it worked before you put it in, you most likely have it installed wrong.
The capacitor should be put in parallel with the main +B voltage of the amplifier. That means you would connect the positive side of the capacitor to the +B voltage supply of the amplifier and the negative side of the capacitor would go to the chassis ground.
If you have it connected in series, or inline with the +B voltage supply, the capacitor would be blocking the voltage to the amplifier.
Without more information on your problem that is the best answer I can give you.
If this does not help, please supply more information and I will be happy to help you further.
Jun 18, 2008 | Rockford Fosgate Car Audio & Video
Rockford amp cut out
Disconnect all speaker wires from the speaker terminals of the amp and disconnect the RCAs. Replace the 30 amp fuse with a 15 amp fuse. If you turn it on and it blows the fuse, it's likely that it has shorted output transistors. If that's the case, you need to have the amp repaired.
Dec 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
Car Audio & Video Logo
110 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
