Question about Lexmark X1150 All-In-One InkJet Printer
Lexmark x1150 will not print out seems to start then comes through paper feed quickly and doesnt print anything
    Genius:
  • 2,785 Answers
Plz reinstall the printer drivers
Posted on Jun 30, 2008
Why does the paper jam and a loud noise come from the iP90 printer?
Most likelt to be a foreign object or wad of paper crammed into part of the paper feed roller. The first thing to do is turn it upside down and give a few sharp solid taps on the bottom casing. Then check to see if anything falls out. Also check the leading edge of the paper that didnt go through for marks that might show where it was stopped. If you are sure there is nothing to stop paper feeding through, check at each end of the print head path inside for a clump of ink soaked paper - remove if found. Try feeding a sheet through again. If the paper doesnt feed, try slipping a thin stiff card or plastic sheet back through the feed mechanism from the front. If that doesnt go through, you will have to disassemble the printer to find the problem.
Jun 27, 2014 | Canon PIXMA iP90v Printer
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
I have a new pixma ip5200 inkjet,never used and it just comes up
Dear hemi1223,
It seems that the printer has problem with feeding mechanism. Here are possibilities: some materials block paper end so it does not reach paper cam sensor, paper feed sensor error, broken paper left inside printer and sheet feeder part broken. I suggest you to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 22, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper Feed Problem
I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
Paper keeps jamimg
u break it and put it in the dustbin
Dec 13, 2007 | Lexmark X7170 All-In-One InkJet Printer
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
