Question about Ricoh Aficio 1035 Copier
Ricoh 1045 only printing on 1/2 page
Our ricoh afifio 1045 was not printing anything until I put some developer type 18 in, it was just outputting blank pages, but now it is only printing on 1/2 the page...
any ideas why it would print 1/2 the page of everything we try to photocopy and print?
Regards,
Phil
  • 5 more comments
  • phillipm Jun 30, 2008
    yes i found the service manual for the machine and emptied the old developer as instructed, didn't go in to service mode.. what would this do?
  • phillipm Jul 01, 2008
    Just tried going in to sp2 - 801 but the execute command was shadowed.
    yes I got in to the service mode by doing the following commands:-
    1. press the yellow c button
    2. type 107
    3 press and hold the clear button until you enter service mode
    doesnt allow me to make up a six digit number..
  • phillipm Jul 10, 2008
    Bubbabear64,
    When typing in a number on the numeric keypad and on the screen it won't register and the execute command is still shadowed.
    Any other ideas?
    Doesnt accept any six digit number.. still shadowed out.
    Ok It let me execute after entering # after the six digit number
    Prints look worse now thought
  • 62 Answers
Check the glass **** next to the area you slid the developer unit into. Chances are it is half covered with toner.
Posted on Jul 07, 2008
  • Ricoh Master
  • 2,794 Answers
When you put the delveloper did you:
remove the cover to install it.
remove all of the old developer out of the machine.
Did you go into service mode and run sp 2-801.
Posted on Jun 30, 2008
  • 3 more comments
  • Tim Babcock
    Tim Babcock Jul 01, 2008
    There is a TD sensor above your drum that gets calibrated. If is isn't performed it will cause copy quality issues.
    I'll find out why the command was shadowed. Do you know what buttons to push to get into service mode?
  • Tim Babcock
    According to Ricoh no copies should be ran on the machine until sp 2-801 is performed after the developer is changed. If there isn't a six digit number on the developer Make up a six digit number and press execute.
    If the copy quality continues, you may have to redo the developer process as well because the toner mixture could be messed up depending on how many copiers you ran.
  • Tim Babcock
    If you type a number on the numeric keypad it isn't registering? If it doesn't try touching the field and use the blue buttons to type a number in.
    One that is completed run sp 2805 as well.
  • Tim Babcock
    Tim Babcock Jul 10, 2008
    You can type in any six digit number and it will accept it.
  • Tim Babcock
    Tim Babcock Jul 11, 2008
    It could be the developer is contaminated if there were a lot of copies ran on it before the calibration. It probably can't be resolved unless it is done over from scratch.
How to fix 990 erro code without changing a drum ?
what model is it. that sounds like more of a hard drive issue than a drum issue.
Nov 22, 2014 | Ricoh 888073 Genuine Aficio 1035/1045 Type...
How can I convert Ricoh development counter to pages
Best thing to do is contact Ricoh Services and Support (1-800-432-9787) for service. A Ricoh Tech/Engineer would need to go into Special Service to change the Accounting type preferences, as end-users shouldn't have access to this Special Service function. Additionally, once this change has been made, you cannot revert back; you can only change this setting once.
Jun 02, 2014 | Ricoh Aficio™ SP-C210SF Printer
Ricoh afficio 1045 & ricoh 450 toner is mixed in ricoh fw 780 now background and negative image is coming what can i do plz give some idea
firstly you need to remove the developer and vacume the developer unit and magnetic developer roller.
Put in new developer and correct toner in toner unit.
Call service...
After replacement there is a sequence wich needs to be done, for developer initialization.
Aug 16, 2011 | Ricoh FW 780 Black and White Copier
A ricoh 1045 sc990 code says about Hard Drive problem. Where is this located? also please tell me what is and where is located a developer? Thanks in advance.
SC 990 is a software performance error.The software attemted to perform an unexpected operation.Software defective,internal parameter inncorrect or insufucient working memory.SC 990 occues when printing a message dtored in the information box.Avoid by firmware upgrade.This information can be cheked by using SP 7-403.The hard unit is located in rear right side up position of by pass.The developer is under toner botle in developer unit.
Aug 01, 2009 | Ricoh Office Equipment & Supplies
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 03, 2008 | Computers & Internet
Ricoh Aficio 1035 Copier Logo
498 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
