Question about Sony Ericsson HPM-70 Consumer Headphones
Sony ericcson head phones
My right earpohne doesnt work..it only works when you fiddle around with the wire near the button area
should i just buy new ones, or can this be resolved?
coz i am a big fan of music and i absoloutley love my headphones.
  • 1 more comment
  • Anonymous Oct 20, 2008
    I too have the same prob......
  • Anonymous Apr 16, 2009
    Yeah, I'm getting the same problems... Initially my left headphone stopped working unless I fiddled with the rubber coil underneath the plastic of the headphone itself, which was annoying since I had to hold it in place, and then the same happened with my right headphone. Any solutions, people?
  • james_parker May 17, 2009
    yes i have same problem
    but i will try to cut the wire and join
    EXPERIMENT
Sony ericsson's should just have a 3.5 headphone jack insted of the dodgy plug they have now.
Posted on Dec 14, 2008
Your earphone is damaged, u'l have to buy a new one as it cannot be fixed.
the reason might be, that u may hv streched ur wire accidentally, which damaged the internal wire(as it got pulled).
Posted on Oct 23, 2008
I have similar problem, the only difference is I have problem with left headphone
Posted on Jul 16, 2008
Turn on, hold is displyed then it turns off quickly
There are 2 ways you can go about fixing this:
1st is the proper method - After unscrewing the screws near the usb head, take off the cover. Near the jack input area is another small screw, take it out. You can now take out the main board by pulling away from the jack and up. Take a look at the but end, where all the copper foil is. Do NOT remove the copper foil or the tape around, it is your ground (protects your chip if sparked). If you see a blue t shape thing that is your switch. If you don't, check answer 2. This blue T switch has to have the base of the T in-between the 2 forks on your hold switch. After fiddling for a while you will get it and then just screw everything back together.
2nd method - You will need some metallic wire and tape. IF you do use this method you can NOT use the hold function, unless your are skilled at fiddling with wire. You will have tak some of the wire and make an oval ring shaped hole with it. Press the wire ring through the hole below the copper foil. you want to press the ring upwards. Press the power button and make sure it is in the proper position. If not then fiddle around until you get it.Once you have achieved the position tape the ring down in it's position. Turn on the mp3, if it works good, you now get to re-assemble. If not then, go back and fiddle with the wire and tape again. (You might achieve the same goal if the wire is straight BUT the wire moves easier). Once it is all back together turn it on one last time and if it works embrace the hard work you just did. If not, sorry to say, go back to step 2 and start over again.
***Both Methods Work***
*I did both and my own unit still works*
From The Tech Knight
Mar 15, 2009 | Sony Walkman NWZ-B105F MP3 Player
White display on sony ericcson T630
Hi. Ift's a common problem and requires a new LCD. It's an easy job. There's a guide here and you can buy parts from the site http://www.formymobile.co.uk/Dismantle/t630_dismantle.htm
Nov 12, 2008 | Sony Ericsson T630
White screen problem
the phone needs to be reflash to correct this issue this can be done online at a paysite called topsony.com or you can take it to a mobile store near you to have it flash there.
Sep 05, 2008 | Sony Ericsson W550i Cellular Phone
How to download the pc suite for my cell phone
pls give me the w7ooi pc suite software my mail address thank sir
Dec 17, 2007 | Sony Ericsson W700i Cellular Phone
My psp sound has gone
The jack where the ear piece enters gets partial contact try and get standard ear piece cause you cud damage the sound unit if you keep feeding it partial current
Sep 30, 2007 | Sony PlayStation Portable (PSP) Console
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
Sony Ericsson HPM-70 Consumer Headphones Logo
494 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Dai Boyce
Dai Boyce
rajesh ettapurath
rajesh ettapurath
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
