Question about Hoover Dishwashers
Our dinner plates hit the rotating arms of the jets. We have checked the manual and we are loading correctly. Just doesn't make sense.
  • Anonymous Mar 24, 2014
    I've loaded the place as described in the manual but the spray arm can't rotate.
Solution - there are 2 sets of rollers about 2 inches apart. You just click off the stoppers at the end of the sliding arms on the top shelf, take out the rack and put it back onto the higher set of rollers!!!
Posted on Jul 07, 2008
  • 1,462 Answers
Dinner plates are too big!
however, often the top basket can be repositioned to go higher which should solve the problem
Posted on Jun 30, 2008
Kitchenaide rinse dispenser in dishwasher doesn't work. White soapy streaks on plates
Confirm that lower washarm is rotating. Initially check by rotating by hand. Second mark arm position turn on unit stop and heck arm position.
Listen very carefully and confirm arm is turning. It is often found debris clogs the lower arm jet preventing the arm from turning.
Also check the water level in washer sump. Low will also keep the arm from rotating.
Hope this helps.
Jun 29, 2017 | Dishwashers
Dinner plate stops arm rotating, plates must be able to go in. why is the arm hitting the dinner plate.surely you must be able to wash your dinner plates in there, from tray to arm is 250cm.
on the topshelf of the dishwasher there are 2 lots of slide wheels . these are to set the shelf at different heights they should be on the lowest wheels to give you the maximum distance between the bottom tray and the spinning arm
Jul 30, 2011 | Dishwashers
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
Glasses not getting cleaned on inside
It could be a packing problem, check you manual for the correct method to pack various items in the machine, otherwise it might be that the arms are not spinning freely. Check them first to see if they rotate easily when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
May 03, 2011 | Dishwashers
Dish not realy not clean leves film on them same soap as alwayes
Hi. Check that the arms are spinning. Something maybe jamming arms like a knife or fork sticking below the basket hitting arm or check that the jets, particularly the end jets are not blocked. Easiest way to check if spinning is to rotate arms into a known position and start a cycle with dishes in machine. After say 1 minute open door and see if arms have rotated. Cheers. Slavious
Sep 24, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Water spinner hits dinner plates and cannot turn. i can see no way to adjust the dinner plates are average size i didnt have a problem with my other dishwasher.
Check the side left & right side. There should be an adjustment. Pull the rack and observe. you might have to select the lower rails.
Refer your user manual.
May 24, 2010 | Dishwashers
Normal dinner plates hit the top washer arm in Bosch dishwasher
Feb 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Arms don't seem to be spinning
chances are there are either dishes that are too high or utensils dropping down in the way. Adjust the height of the racks to accommodate your large dinner plates.. also spin them by hand and see if the spin easily.. if not could be several problems.. also clean the filters in the bottom of the dishwasher. Remove the arms and check for blocked jets.. I found rice in my jets. Rice should be rinsed off the plates first... many people have rice issues.
Dec 13, 2009 | Maytag Dishwashers
Rotary jets not spinning
Hi there........Rotary jets not sinning can be caused by....(a) something impeding their rotation..dishwasher air freshner hanging in incorrect place...(b).incorrect position of upper tray resulting in large plates impeding spray arm rotation...(c).cuttlery basket incorrectly placed or loaded with cuttlery impeding spray arm...(d) wash pump blocked or damaged impeller resulting in insufficient pressure to spray arms...
regards Sir Galahad
Aug 12, 2009 | Dishwashers
Dishwashers Logo
290 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
