Question about Samsung ML 1450 Laser Printer
Printing is very poor
I have samsung ML-1450 laser printer, but it is not working properly it leakage the ink and paper is partialy clear in middle and print only left and right side of the page while printing.
  • 104 Answers
Replace toner
Posted on Jan 06, 2009
  • Superness Nov 17, 2010
    I have the same problem, the thing is that I use that printer on my network and it has that problem on two clients only the other clients prints fine.
    Already checked printer settings on the PC's with the problem and print quality is the same that in the other computers.
If the orange light is on and remains on does that mean that the toner is out of ink and needs to be replaced?? When you press print it makes noise but won't print anything and then the orange light is on.
Per Samsungs website:
When the toner cartridge is near the end of its life:
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
Laser printer manual feed jam
like the name goes, it is manual. You will have to feed the papers one after the other. if you do not want that, then load the papers into the automatic tray if you have one.
Incase none of the above works it means the roller that is suppose to pick the papers finds it hard to pass papers on to the other which you will have to replace.
good luck
Jul 04, 2010 | Samsung ML 1450 Laser Printer
Print distorted and solid toner column with Samsung ML 1450
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
I have lost the software/driver of my samsung printer ml 1450,now i can not install online.
Here is the link for the windows driver for your printer.  http://printers.free-driver-download.com/Samsung/14072/Samsung-ML-1450-Printer-Driver-Windows.html
If this helped you please rate, thanks!
Jan 13, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-1450 "Time out" error
I would try to reinstall the drivers for this printer and make sure it is your default or selected printer. It sounds like the drivers were changed or corrupt. Any new software install may of done this. Also try to let the printer be unpluged from power for 24 hours.
Jan 08, 2009 | Samsung ML-1450 (Open Box) Printer
Samsung ml 1450 printing problem
either paper is stuck in it somwhere, your carts are **** or the fuser is worn out.
Dec 17, 2008 | Samsung ML 1450 Laser Printer
Samsung ML 2010 Laser printer
LSU means "Laser Scanner Unit". That is the part that actually "prints" the image on the drum before it goes to the paper. If the toner (not ink) cartridge is in good condition, then you need an Authorized Service Center to replace the LSU assembly.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML-1440 Print Problem
SOME PIECE OF PAPER ETC IS STUCK IN THE FUSING, PLEASE CLEAR THE SAME , PROBLEM SHOULD BE RESOLVED OMNIPRESENT
Aug 26, 2006 | Samsung ML 1440 Laser Printer
Samsung ML 1450 Laser Printer Logo
96 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
