No signal on my Benq DLP630 projector
Hi there, i have a projector, i have tried connecting it to my laptop as well as various others. at first it gives the no signal alert. but then after some fine tuning with the display and resolution settings it comes right. can you please let me know on what the display settings should be and how i sort this problem out. because eachtime i have sorted the problem out it has been by complete accident.
Help me please
  • Anonymous Oct 31, 2008
    Same problem, but I thought with the new BENQ we do not have to use the lap top keys to connect with each other? Should it not auto connect. If not what do you suggest we do besides the tap dance of who is turned on first?
  • 682 Answers
Please make sequences in switching on-turn your laptop on first and projector second-use fn key in combination of either f4-f5-f6-f7-confirm input signal selected(computer).
Posted on Jul 08, 2008
Yep exactley what is happening to me No signal!! Annoying i really need help
Posted on Apr 24, 2014
Why do i have vertical lines on benq projector?
Probably because the signal going into the projector is a different resolution to the panel. The projector has an auto sync feature. But that only helps so far. Try changing the laptop resolution to match the native resolution of the projector (the pixels) and not the maximum resolution.
Aug 27, 2014 | BenQ Office Equipment & Supplies
I bought BenQ MP670 Projector second hand for 100 euro.So my problem is that when iI connected my laptop with my projector via HDMI cable, I got no sound.It is not the cable,I use it to connect my laptop...
Depending on what type of laptop or projector you're using the HDMI me not carry the audio signal. you may want to see what your audio outputs are and try hooking them up in addition to the HDMI
Nov 05, 2013 | BenQ MP670 Projector
Power but no display
you have to change the video out put on the laptop and it is differant for each setup if you are running win 7 you will find connect to projector in the control panel
Apr 28, 2013 | BenQ Office Equipment & Supplies
My laptop does not recognize the projector
Try to send 'only to projector'.. If you are trying to see image from both, maybe your video card can not support it...
Mar 02, 2010 | BenQ Office Equipment & Supplies
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
How do i get sound out of a benq cx660 projector!
Hi I am Vortash .. you need another connection from the laptop earphones to the audio in on the projector . that would be a 3.5 mm stereo jack to twin phono .. or if you have a line out on the laptop from there , if you do have this connection then you may need to activate the sound input in the menu of the Projector .
hope this is of help Regards Vortash
May 17, 2009 | BenQ PB6100 Multimedia Projector
Not working on my laptop
Hi Jhem,
It definitively sounds like either a Screen resolution or a Screen Refresh rate problem. I would suggest you start at the bottom: set your Screen Resolution to something very low like 800x600 and set the Refresh rate to 60Hz - both in Windows of course - you'll probably have to do this with you regular display attached to you PC first, then connect your BenQ second. Than move your way up to the recommended spec in your BenQ User manual.
Cheers
May 15, 2008 | BenQ PB6110 Multimedia Projector
1,435 people viewed this question
jasbo
jasbo
