FixYa.com
Tags:
Toasters
Generic problem for all Toasters
Cord replacement
posted by ingredient on Jun 30, 2008
the cord needs to be replaced as it doesn't connect unless twisted.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 30, 2008
Not Rated (0)
Dacopper
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
If the break is near the plug, cut it and put a new plug on (three prong if the original is, two otherwise). If the break is too close to the cabinet, you'll need to replace the whole wire with something of suitable size (remember, this is probably a 1000-1500 watt appliance!). Opening the cabinet shouldn't be too difficult and if you replace one wire at a time, you can't get lost. You may need to cut the wire short of a junction of several wires (better than cutting all of them and wiring them in to a new junction with a wire connector). I would tend to solder the wires you've just connected, although many would suggest those screw on wire connectors. A lot has to do with how much room you have in the cabinet. If you aren't at all mechanically inclined, get a friend to do it. Or buy a new unit (a last resort in THIS household and not used until the unit is thoroughly unusable!).
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: APW Wyott BT152230V Toaster Betty Crocker BPL-600U 2-Slice Toaster APW Wyott AT-Express Conveyor Toaster Black & Decker BLD-T4500 4-Slice Toaster Black & Decker Black & Decker Arize Electronic Toaster 2-Slice Black & Decker Classic Chrome T4029 4-Slice Toaster Black & Decker T4200 Toast-It-All Deluxe 4-Slice Toaster
Can you Help with these Toasters problems?
Back to Basics TEM-500 Egg & Muffin 2-Slice...
Bread toaster doesnt work
My parents just bought this... Answer This...
Toastmaster TP409 4-Slice Toaster
toaster control gone
toaster control gone Answer This...
Breville CT75XL 4-Slice Toaster
Breville CT75XL 4-Slice burned...
At first it just appeared stuck... Answer This...
Toasters
Toaster Problem
Hello I have a 2 slice Russell... Answer This...
vintage toaster doesn't heat...
vintage toaster doesn't heat... Answer This...
Repair Service
Find Toaster Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
