Question about Compaq Presario-Notebook 900 Series Video Boards- DQ044-69002 (DQ04469002)
I can,t hear audio from s-video port. can it is possible the audio is output from s-video port
    Problem Solver:
  • 15 Answers
No that is not possible, sorry
Posted on Jul 02, 2008
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
Hi, I want to know if there is a way to watch tv (sound & picture) with a htmi cable or similar even if I do not have a hdmi port. thank you
You might be better off with external speakers connected to the laptop's audio output. Flat panel TV speakers tend to be weak.
If you want to continue with the HDMI option and your laptop doesn't have an HDMI port, try a USB to HDMI adapter. Look carefully, some models output 720p not 1080p. One possible unit: . However, your video rate may be sluggish due to the limits of the USB port. (If you have a USB 3.0 port on your laptop and find a USB 3.0 adapter, it won't be as bad. USB 2.0 adapters are more common.)
Look at the specs for your laptop or add a comment with the make and model. My mom's HP laptop (purchased in 2009) has an HDMI out; however, the audio driver doesn't go to HDMI out by default.
You may need to adjust the audio output options. (In Windows 7, Start > Control Panel > Hardware and Sound. Then Select Manage Audio Devices under Sound. Check the Playback tab for your audio output options and change the default device if needed.
I hope this helps.
Jan 17, 2013 | Computers & Internet
Vtc m20 betamax video cassette recorder; is it possible to link it to an 824 33025 Tosiba 32DL933 32 large screen wall mount television
Only if the new TV has Component input ports, that is the two audio cables usually red and white and the yellow video cable.
May 03, 2017 | Televison & Video
Cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
I can hear everyone on video calls but they cant hear me
Check for mic settings in control panel> sound speeches and audio >speech >audio output and make sure use preferred audio output device is checked.
Also make sure mice cord is connected to right port
make sure mic is not set to mute.
Apr 17, 2011 | Computers & Internet
I have a Sanyo DWM-390 DVD player and I can't get the video on my TV. I have the DVD player going directly to my TV versus my cable box. I have the video and audio chord in the corresponding audio and...
3 possible solutions to your problem starting with the easiest:
1. The audio/video cable is bad. It is possible the video side of the cable has a short.
2. Inputs on the back of the TV are mislabeled or aren't matching up with how you are connecting or using the inputs. Feel free to post a picture of the back of the unit with your cords attached and I can tell you for sure.
3. Some dvd players require you to select which video output mode to use. Most of the newer ones come defaulted to hdmi output and might need a menu selection changed to output using component or composite outputs (whichever you are using). Composite will just have the red and white connector for audio and a single yellow connector for video. Component uses the same 2 audio connectors and then red, green, blue conectors for the video.
Let us know more detail and I can help further.
Jun 14, 2017 | Sanyo DWM-390 DVD Player
I set up my web cam and i hear my sister when she talks but she cant hear me
well the first thing that you got to check is that if the web-cam has an inbuilt mic to it
If there is no mic then you will have to attach a seperate mic/headset for voice
Also check if its USB port or normal Audio/Video output...if it had audio/video cable then you will have to attach both the cable to the correct port in the Cabinet
If it has USB output cable with inbuilt mic then try to unistall and reinstall the driver software and attach the the webcam only after installing the drivers
Jun 14, 2010 | Logitech Webcam
Acer Aspire 1690 Audio output not working
For audio output: I would locate the latest audio drivers for your speaker system - a few possible solutions:
1)Best: Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> Sound, video & Game controllers - look for a yellow exclamation mark by any of the devices, right click that device and click install drivers [note - this procedure will also work for your port problem, most likely; if not, just remove the port, restart your computer, and the "found new hardware wizard" will re-add it properly upon startup]
2) just enter the manufacturer nad model number of your spekaers in search bar and include the word "drivers" as your search term.
3) Go to
Jun 08, 2008 | Acer Aspire 5100 Notebook
Onkyo TX-SR605 hdmi output jack was damaged and needs replacing. A) Where can I get the part and how much for it? B) Does the replacement part require solder or is it a snap in type connection?
The hdmi output and inputs are on a modular circuit board that you only need a philips screwdriver to swap out. I need this board as well since I also have a damaged hdmi output jack but have not been able to locate the replacement board. If anyone knows where to look I would appreciate knowing.
Apr 25, 2008 | Audio Players & Recorders
S-video from computer through receiver
yes, if you use the S-Video output on your laptop to the input on the receiver, then another S-Video cable from the Monitor Out port on the receiver to an S-Video port on your TV. Then select the appropriate source on the TV and receiver.
Be reminded that this receiver will not convert the signal from S-Video to composite video (the yellow cable) nor from composite video to S-Video.
Also be reminded that S-Video will pass only video, not audio. You need a seperate cable to go from a 3.5mm headphone stereo jack to 2 RCA composite audio plugs.
Jan 20, 2008 | Onkyo HTR500 Receiver
Computers & Internet Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
