My Top Loader US Whirlpool LSQ washing machine (5 years old) has developed a problem. The machine fills ok, but does not wash and at the end of the wash cycle the machine empties ok. During the washing cycle I dont think the drum is going round and a loud grinding noise can be heard which to me sounds like metal bearings are grinding together. Any clues please, many thanks, Keith
  • keithxgraham Jul 02, 2008
    Hi Jsrock, just to say I received the coupling today and following your concise instructions I had fitted the part within 2 hours, the trickiest bit was aligning the motor when putting it back together (as you said).
    I am not a DIY person but found this task relatively straightforward, and all for £20 so many thanks once again, Cheers Keith
  • 5,911 Answers
Sounds like you have a failed motor coupling. This is an easy fix, requires inexpensive parts, but is going to take a little effort and know-how on your part. If you click on the following link, it explains step-by-step how to replace the coupling:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is 285753A and can be found at searspartsdirect.com. Just type in your model number and the part will be listed under the "Brake/Clutch/Gearcase/Motor/Pump" heading. If you require further assistance, please let me know. I hope this helps you resolve your washer problem.
Posted on Jun 30, 2008
  • Jeff Rockwell
    Jeff Rockwell Jul 02, 2008
    Keith,
    Thank you for the kind words. I'm glad you were able to correct this "simple" problem and get your washer working again. I think you can officially call yourself a "DIYer" now. Great job!
    Jeff
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Have a lhw0050pq4 ft loader washer (whirlpool) 5 years old little use. in 5th wheel trailer and it seems to lose its place in the cycle can you help?
The control board will need to be replaced. It is located on the top, right hand side of the unit as you look at it from the front. Remove the screws on the top panel, slide it back to remove it. You will see the board. Here is the board to order.
Oct 29, 2012 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Washing comes out with marks
Yank that dispenser off the top of the agitator and wash some clothes without it.
Apr 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LSQ 9520 LQO Top loading washer
See the solution I provided under your other post. I believe your problem is attributed to a faulty lid switch.
Jun 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
