Question about Kitchen Ranges
I want to replace the grill element on a Westinghouse upright cooker - Kimberley 501
A bit further investigation revealed the following:
Remove the two black clips on either side of the rear of the grill element and the element will come loose. Remove the connection lugs (two on the left and one on the right) and install the new element. Caution is needed because the element connection lugs do not have a lot of excess wire on them and may require the removal of the back of the cooker to effect a good replacement.
Posted on Jun 30, 2008
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
Westinghouse kimberley 509 upright oven. How to reset time of day on the clock ?
Press the "clock" button. Either enter the time digitally or use the "up" or "down" arrow buttons to scroll to the correct time, then press the clock button again.
Sep 17, 2015 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Need part number for westinghouse kimberley 501 oven element PAJ501R
WESTINGHOUSE PAJ501R not working at all. Fuse and safety switch all ok.Does this oven have an internal fuse? thx stephen
Aug 28, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Kitchen Ranges Logo
393 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
