SOURCE: LG KP220 PC SUITE?
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC! Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3):
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista:
When you first connect the phone in COM mode, let vista download the driver from the internet. Then run PC Sync and viola it'll work!
For both:
For running as a USB flash drive (data mode), you don't need any driver in either o/s.
For running as a COM port (phone mode), you need a driver and a software. The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek. I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works. Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
SOURCE: how can i download lg pc suite for KP115
My Lg kp115 is not showing the memory card and its stuffs ,please help me to access it
SOURCE: Where can I download LG PC Suite ? No PC disc
Hai
You can use this software for LG KP 220 to connect the internet.
http://www.ziddu.com/download/8112974/PCsync.zip.html
from
hkmthumma
