Question about Intel Motherboard
Sata driver I have a MSI motherboard.. It is not able to find the HDD while installing XP..How to go about it??
  • vishalpatel1 May 11, 2010
    is this a SATA HDD?
    before you installed XP, did the HDD show up in BIOS?
    President:
  • Intel Master
  • 1,314 Answers
You need to turn the ahcp in the bios to ide mode. This will allow xp to see your drive.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 18, 2008
    Sergeant:
  • 287 Answers
Check the BIOS and ensure that you have the following set
boot order CD 1st Hard Drive 2nd, then check to ensure that the boot priority shows your Hard drive as the first drive .
for more specific advice please provide the MSI board model number
Posted on Jul 17, 2008
4 Suggested Answers
  • 489 Answers
SOURCE: can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
You have a board with 4 SATA ports on it and a SATA HDD. The hardware detection routines will see this and load the SATA drivers. Why would you even want to try to set it up without them?
Posted on Mar 21, 2009
Sarethan
  • 76 Answers
SOURCE: Intel D945GCCR SATA driver problem.
You shouldn't need the drivers till after the OS is installed.....just go into BIOS and check to see what placement it is in.....or boot up the windows XP CD and select it as the drive to reformat and install XP on. In Bios you can select which drive you want to boot. i.e. IDE/SATA it should have a model number of the one you have selected to boot just make sure it matches the modle number of the drive and you good.
Posted on Nov 02, 2009
ykeen
  • 39 Answers
SOURCE: my motherboard is intel d845gvsr
For sata HDD Your can connect your sata HDD using IDE to SATA cable. Intel 845 can support upto 320GB only.
Posted on Mar 17, 2011
Hi, I have a msi n1996 865gvm3-v motherboard and it doesn't want to pick up my sata drive, what to do?
If you are trying to install Windows XP and it does not detect the SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 14, 2011 | MSI 865GVM3-V Motherboard
I have hdd sata and i want to setup win xp on it my motherboard is MSI (MS-7104 VER:1.0)
The Windows XP installation CD does not have a SATA driver. Please click on this link and follow my instruction for Windows SATA installation :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Aug 16, 2010 | Computers & Internet
I cant install windows in sata hdd for msi pm8m-v
Thank you for your question.
In this case, my opinion would be that the SATA Driver needs to be installed from floppy disc before the install of Windows. It is at the beginning of setup at the bottom of the screen in black writing on a grey background for Windows XP. It says "Press F6 if you need to install other drivers". This is your cue to press F6, the install will load drivers from there to enable the SATA on your motherboard.
If you do not have the motherboard discs, I have attached the link to the makers download page for your motherboard, you can obtain the SATA driver from here.
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=205
Good luck with your install.
Kind regards
Apr 28, 2010 | MSI PM8M-V Motherboard
HOW TO INSTALL WIN XP ON SATA HDD ON MSI K8MM -V M/B
If your copy of Win XP does not recognize the SATA drive (i.e. Early copy of XP) you will need to use the F6 option and load the SATA driver that came with the MSI mother board.
Mar 24, 2010 | MSI K8MM-V Motherboard
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
Ineed cd support for MSI 661FM2-V (MS-7060)motherbord, because i lost the original and now i want to install xp sp2 on sata HDD
you can get manual, driver, bios for your motherbord at the MSI mainboard website http://global.msi.eu/index.php?func=proddesc&maincat_no=1&prod_no=158
choose XP driver
Succes with installation
I hope this information is helpfull
Aug 29, 2009 | MSI 661FM2-LSR (7060020R) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Motherboard stop recognize SATA HDD after BIOS reset (default)
You'll likely need either a driver disk for your SATA drive to be recognized by Windows XP during installation or Windows XP with Service Pack 2 built in to install without a driver disk.
Creating a Windows XP installation CD with Service Pack 2 or "SP2" built in is fairly straight forward. This is called "slip streaming". Step - by - step directions can be found in the following links:
http://www.google.com/search?q=slipstream+sp2+windows+xp&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Mar 27, 2009 | MSI 865PE Neo2-V Motherboard
Drive SATA 3.0 Gb not detected by msi 7060
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Nov 20, 2008 | MSI 661FM2-LSR Motherboard
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
