Question about Vizio L32 32 in. LCD HDTV
Burnt smell TV works fine but at times I get a smell of burnt wires or ? at the top right hand of the tv.
    Sergeant:
  • 280 Answers
Most like the capacitors on the inverter board or power supply are going leaky.. if you look at the board you will notice that the caps are puffed out at the top. replacing them if difficult and if you don't have the skill to replace them have a good tech do it.. repairing the board is much cheaper that replacing them.
As the caps get worse the set will stop cumming on.
Posted on Jul 07, 2008
My toshiba 32" tv has a burnt plastic smell, I've heard a couple of people say online that maybe it's because it is new,I've had th tv for maybe 3 weeks, and was wondering if my tv is gona stop workin
how new is new
if un packed in the last 5 days
i would say its the new smell
give it a week to "burn off "
the factory assembly smells and glues
use the back of your hand
run it over all the unit see if you feel hot spots
the only hot spot will be heat on the outer casing
from the power source inside the TV
Aug 06, 2016 | Toshiba Televison & Video
Burnt wire smell Board Flashing Br
The unit was running when we came in. No Storms in the area. it was blowing hot air, but was still on the cool setting. There was a burnt wire smell coming from the unit. And the diag. code was Br. I found this odd since it still had power.
Aug 16, 2014 | Amana PTH153B50AM Air Conditioner
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Mitsubishi lt 52149 52 hdtv will not come on. Like no power. Smell burnt smell at top. Is this something I can possibly repair myself if handy?
No,tv do not any indication of any LED lights that light up at all or any blinking LED lights at all wright?Yes?This tv have major components parts on in one board or could be any boards parts are completely fries and could spread all over the tv other boards too.That why u able to smell burn smell,minor problems don't have a deep smells like that.Best get a quotes from tv Techs from many tvs shops best prices u decide and get it fixed by a tv tech certified professinal.
Aug 22, 2011 | Mitsubishi LT-52149 52 in. LCD HDTV
When I turn on the TV it "pops a few times" then I turn it of and turn it on and it starts. Now today it seemed to go out and then I smelled burnt electrical smell.
It definitely sounds like it's time to have a TV repair man come check it out, or you will have to bring your TV into a TV repair shop. If you are familiar with working on TV's and have the proper equipment and electrical knowledge, you may be able to take apart the TV yourself and check for damaged capacitors, or boards that need to be replaced.
Aug 03, 2011 | Mitsubishi VS-50501 50" Rear Projection...
Hi, LG 42" today started
you need to take rear cover off to inspect whats happened ..u will see or smell what gone wrong if done asap... UNPLUG FIRST ....
Feb 27, 2011 | LG Televison & Video
The tv smells like a burning wire
Can you describe where the odor is coming from. Is it coming out from the side panels on the tv set itself, or perhaps the plug, on end of the main power wire. Check around the electrical outlet. Make sure nothing else is plugged into the same outlet. It sounds as if some of the electrical components on the circuit board are burnt or burning out. Tv may have experienced a power surge, etc. Check also if the power plug is heating up. Be careful and smell around top side vents on tv. Be sure and unplug the set before leaving it unattended if you cannot locate the source of the "burning wire smell."
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | Televison & Video
Burning wire or plastic smell coming from back of t.v. on top right hand side tv is functioning normally
Open the back cover and look for bulged or burst capacitors. If you can locate any then change it with the ones that has exactly the same specifications.
Nov 08, 2009 | Maxent MX-27X2 27 in. LCD Television
Burning smell on right side (facing tv)
contact a repairer ur wire inside tv has burnt
Sep 03, 2009 | Philips 30PW8420 TV
Vizio L32 32 in. LCD HDTV Logo
220 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
