I have a vinotemp VT-12TEDi wine cooler and it is plugged in but the unit is not working. will not power on, not cooling inside and unit led is just flashing "0"
I have a different model Vinotemp, but experienced the same exact problem described here where the LEDs on the controller board blinks and there is a clicking or chirping noise. It turns out there was a bad electrolytic capacitor on the controller board that was visibly noticeable (it was bulging). Replacing the capacitor fixed the problem. On my model, it was a 1000 microfarad 16v cap, available at RadioShack or any store that sells electronic components for less than $1. Of course, you will need some soldering skills for this fix.
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's. See: http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
First check the grating over the fan in the back. If it is covered
with dust, there won't be enough air flow and the unit won't cool.
Clean the dust off and see if it cools back down. It may take a long
time to cool down if it is full of wine, so I recommend taking the wine
out to test if it works.
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
